Dynaudio alternatives
Old 25th September 2013, 01:03 PM   #1
boom0789 is offline boom0789
Talking Dynaudio alternatives
Hello I'm looking for some advice. I was looming at getting the below drivers for a 3wat design but I'm finishing it impossible so find them.
Dynaudio 24w 100 / df 76 / d28-af
Can anyone recommend where to find these? If not does anyone have any alternative driver and crossover combinations that will give similar if not better results.
Old 25th September 2013, 01:19 PM   #2
Charles Darwin is offline Charles Darwin  United Kingdom
Dynaudio stopped selling drivers for diy about ten years ago.
They still replace damaged ones but you have to send in the dead ones.
FWIW Morel build very similar ones but not sure of direct replacements.
Old 25th September 2013, 06:21 PM   #3
Inductor is offline Inductor  Portugal
Inductor's Avatar
I will be pleased to look at this thread, just give me some time for background work looking at drivers... and inspiration.
I will mark it in my favorites Dynaudio alternatives. Regards.
Old 28th September 2013, 08:07 PM   #4
Inductor's Avatar
boom0789,
From what you ask, you are not being very explicit, you want a speaker with a dome mid driver. There are plenty of comparable speakers and designs/kits. You have to mention your level of aptitude to deal with crossover design and measurements/simulations or ineptitude to make it yourself and working only with finished and tested designs.
The drivers you mention are referenced here with this design for the Dynaudio Xennon3 speaker/crossover (see pic below). Woofer, Mid and Tweeter and kit:
http://www.gattiweb.com/images/dynaudio/24w100_data.pdf
http://www.gattiweb.com/images/dynau...w100_data2.pdf
http://www.gattiweb.com/images/dynaudio/d76af_data.pdf
http://www.gattiweb.com/images/dynaudio/d28af_data.pdf
http://www.gattiweb.com/images/dynaudio/xennon3_1.pdf
http://www.gattiweb.com/images/dynaudio/xennon3_2.pdf
http://www.gattiweb.com/images/dynaudio/xennon3_3.pdf
http://www.gattiweb.com/images/dynaudio/xennon3_4.pdf
To have a similar setup you can either choose a more conventional speaker like one for home/hifi use or another more pro-sound/PA/studio professional type application. For the second type there's a lot of builds with the ATC SM75-150 Midrange be either the pro ""S"" version or the other one. Examples and links here.
Floorstanding ATC K50 & K100 Loudspeakers
ATC Loudspeakers. ATC Monitors. ATC SCM. ATC Speakers. Manufacturers of speakers, monitors, drive units and amplifiers.
You also have this amazing ACCUTON C˛44-8 that is tested here against various others contenders.
Midrange test data
Also look at the pro and home 2" versions of the CIARE HM 500/600.
http://www.lautsprechershop.de/pdf/c...iare_hm500.pdf
http://www.lautsprechershop.de/pdf/c...iare_hm600.pdf
A fantastic 3" dome that would be the closest in size to the Dynaudio would be the Tang Band 75-1558SE.
Tang Band 75-1558SE 3" Textile Dome Midrange 264-857
3-WAY DIY kit using Peerless Exclusive 830884, Tang Band 75-1558SE, and SEAS 22TFF here.
On the Morel CAM 558 and various Morel dome midranges.
Morel
http://www.htguide.com/forum/showthr...-passive/page5
Morel EM 1308 2-1/8" Dome Midrange 287-030
Morel MDM 55 2-1/8" Soft Dome Midrange 287-020
Morel CAM 558 2-1/8" Soft Dome Midrange 287-025
The Madisound Speaker Store
Morel EM 1308 Midrange
Beyma MC115 pro/studio - Various products from Europe
Midrange • Soft dome • Europe Audio
MC115 - Beyma midrange dome 25W 600-12.5 kHz 8 Ohm - Europe Audio
Beyma MC115 Midrange - Beyma MC115 5.5" soft dome midrange. This soft dome midrange sounds very smooth. Beyma midrange speaker components available at US Speaker.
http://profesional.beyma.com/ingles/pdf/MC115.pdf
Dayton Audio Dome Midranges
DC50F-8 - Dayton Classic Dome Midrange - Europe Audio
Europe Audio
Dayton Audio DC50F-8 2" Dome Midrange 285-010
Dayton Audio RS52AN-8 2" Dome Midrange 285-020
Midrange Drivers -- Dome vs. Cone
Visatons 2" domes and ScanSpeak Discovery D7608/9200-10 3" Dome Midrange (D75MX41)
Dome Midranges
In a last note, if what you are looking for is some type of very high frequencies reproduction then look at the Troels design with a tweeter+supertweeter. SP38/13
For a direct replacement, if that's possible, with very close specs, for the Dynaudio 24W100 woofer, look at drivers from Visaton and Aurum Cantus:
GF 200 - 2 x 4 Ohm
W 200 S - 8 Ohm
Visaton W200S-8 8" Woofer with Treated Paper Cone 8 Ohm 292-572
Visaton GF 200 (4+4Ohm)
Aurum Cantus AC-180F1 7" Woofer 296-412
http://www.aurumcantus.com/aurumcant...f/AC-180F1.pdf
Old 28th September 2013, 08:40 PM   #5
Inductor's Avatar
Tweeters having the "same" SPECS, soft dome, dome size/faceplate, 28mm/110mm, as the Dynaudios, the Morel SUPREMEs and ELITEs being of the same DCR and Fs.
Morel SUPREME ST1108 Tweeter
Morel ELITE ET 338 Tweeter
Morel ET 338 1-1/8" Soft Dome Tweeter Matched Pair 277-070
Old 29th September 2013, 11:32 AM   #6
thank you fore all this info i will start looking through today, much appreciated. i will let you know what i decide.
Dynaudio alternativesHide this!Advertise here!
Any EL84 alternatives? sardonx Tubes / Valves 39 18th January 2018 09:45 PM
FS: Dynaudio Dynaudio Dynaudio eded Swap Meet 5 23rd April 2013 06:27 PM
Alternatives to the DTA-2 Leejin Class D 1 13th June 2012 09:41 PM
Alternatives to CS8414 tmblack Digital Source 12 23rd October 2010 01:07 AM
7591a Alternatives wrenchone Tubes / Valves 16 4th June 2009 05:34 AM
