Reverse engineer xover - help please - diyAudio
Old 16th September 2013, 06:29 PM   #1
xymox1 is offline xymox1  United States
xymox1's Avatar
Default Reverse engineer xover - help please
I have what appears to be a complex xover I need to reverse engineer. Its from a speaker system thats not normal. Its very phase coherent. This is the mid-bass xover from a YG Acoustics Anat 3 main module. Im trying to get more bass extension and im trying to figure out if its the xover thats limiting me ?
Is there a way to model this xover ? Some computer based simulator ?
But I also want to understand it better.
Old 16th September 2013, 06:34 PM   #2
xymox1's Avatar
2 of these drivers are hooked to the above xover.. http://www.scan-speak.dk/datasheet/pdf/15w-8531k00.pdf
Old 16th September 2013, 07:13 PM   #3
Frank Berry's Avatar
As I understand, the system contains a pair of mid-bass drivers. They are not designed to produce very low frequencies. The crossover is designed to limit the low frequency energy (the L-R-C across the output of the crossover). You can disconnect one of the three parts and listen. Please be aware that those parts were included for a reason.
Frank
Old 16th September 2013, 07:56 PM   #4
Speakerholic
Cal Weldon's Avatar
Looks like the series notch filter at the end would be the bass limiter. Try bypassing the 5.6 coil.
Usually though, these things aren't put in for no reason as Frank has mentioned so you remove one part, you may end up throwing the whole thing off. A series notch is usually used to flatten the impedance top and bottom to allow the other components to more easily do their job.
Smarter people that me here so maybe someone else can chime in.
planet10 needs your help:
Let's help Ruth and Dave
Old 16th September 2013, 08:24 PM   #5
Wouldn't that just be a mild notch around 700Hz? Doesn't seem like much of a bass limiter to me. Did I miss something?
Old 16th September 2013, 08:29 PM   #6
Speakerholic
Cal Weldon's Avatar
If was intended as a notch, why wouldn't they use a parallel I wonder?
Old 16th September 2013, 08:35 PM   #7
I dunno, I'd guess the resulting change to the load seen by the rest of the filter was useful? Just saying the values don't look like they'd touch the bass.
Old 16th September 2013, 08:36 PM   #8
Dissi is offline Dissi  Switzerland
It's a 4th order low-pass filter and an additional notch flattening the surround resonance at 800 Hz. None of the components does limit the bass extension in any way.
Old 16th September 2013, 10:25 PM   #9
Speakerholic
Cal Weldon's Avatar
Why doesn't the 5.6 choke shunting the woofers in the series notch have that effect?
Old 16th September 2013, 10:57 PM   #10
Because there's a small capacitor in series with it.
Reverse Engineer AlexQS Multi-Way 13 22nd January 2012 09:02 PM
Reverse Engineer A Horn and Construction hornie Construction Tips 2 7th July 2011 03:24 PM
Reverse Xover Calculator ss007 Multi-Way 9 4th January 2011 04:09 PM
Engineer's Amp rkoonce Tubes / Valves 8 19th September 2010 11:10 PM
help me reverse engineer this sub epalla Subwoofers 21 21st July 2006 08:44 PM
Copyright 1999-2017 diyAudio
