tweeter with 98 db sensitivity - diyAudio
Old 13th September 2013, 10:43 AM   #1
Default tweeter with 98 db sensitivity
hi all
I,m trying to find a tweeter to pair with 2 x audax aerogel hm100zo in a mmt configuration
the audax drivers will be used as mids in a 3 way connected in parallel so giving 99 db and hence my problem
I cant find anything for a budget of around $100 per tweeter that has both good power handling and sensitivity needed to match with these mids
the closest I can find is this vifa
Vifa DX25TG09 04 1" Fabric Dome Tweeter | eBay
any suggestions are welcome
Sheafer
Old 13th September 2013, 10:56 AM   #2
Klipsch RB81 II speaker has 97dB sensitivity and has a titanium dome tweeter, but it is installed on a tactrix horn. Don't know if it can do.
Replacement klipsch part can be purchased.
Gajanan Phadte
Old 13th September 2013, 11:01 AM   #3
thanks Gajanan
I will check it out ,I have not heard any thing favourable about the klipsch stuff though so I,m not sure
Sheafer
Old 13th September 2013, 01:50 PM   #4
IG81 is offline IG81  Canada
IG81's Avatar
If wanting to seriously get above ~95dB sensitivity, compression drivers are where it's at IMO. The usual suspects all make great units: BMS, Radian, 18sound, Beyma, B&C, Faital Pro... Selenium and P.Audio have fair units for a lower price. A good CD on a proper horn or waveguide can achieve better pattern control and better dynamics IMO.
IG
Old 13th September 2013, 01:55 PM   #5
To follow up on IG81's post, I strongly urge the OP to visit Zilch's Econowave thread over at audiokarma.org/speakers. There, you will see many examples and measurements of compression driver/horn arrangements. It's got over 3 million views and 15,000 posts.
"It's all about the music!"
Old 13th September 2013, 08:35 PM   #6
thanks guys
I will check out the page mentioned
also ,how close is good enough as a start ? is the vifa I mentioned in the ball park
Sheafer
Old 13th September 2013, 09:48 PM   #7
DeonC is offline DeonC  South Africa
DeonC's Avatar
Hi Sheafer
Madisound currently has a special on the Hi-Vi RT2-Pro Isodynamic tweeters. They usually retail at $246.35, but are on special at $98.00 each. I know this as I want to get a pair myself, but my car needs some repairs and that is more urgent. Oh well, I hope this helps you.
Enjoy,
Deon
I don't suffer from insanity. I enjoy every minute of it.
Have a look at my favorite thread: Interesting YouTube video clips
Old 13th September 2013, 10:00 PM   #8
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Sheafer
http://www.faitalpro.com/products/fi...atasheet_8.pdf
I don't know it
but maybe it would work
sometimes we know very little, and sometimes we know too much
Old 13th September 2013, 10:12 PM   #9
ScottG is offline ScottG  United States
The problem here is combing and driver separation dealing with the two mid.s used higher in freq. with any tweeter that isn't small.
A few ribbons and planars are available.. but they can't be crossed over particularly low.
This makes the overall design difficult - especially at a budget. (..worse if it's an MTM, rather than a TMM or MMT.)
One way to design with this in mind is a particular network structure (with delay for the tweeter when compared to the mid.s) where the tweeter is opposed to the MM line - i.e. to the side of the MM line, and specifically to the *outside* of the MM's.
Ex.removing or cutting down the dispersion control plate on the HiVi RT2-Pro and having it beside the line of MM's. You can see from the photo here that the back is much more narrow than the front plate suggests:
Product information:RT2-Pro Isodynamic Tweeter
perspective is everything
Old 13th September 2013, 10:54 PM   #10
brig001 is online now brig001  United Kingdom
This might be under your price range, if that makes sense, but what about the Monacor DT-80?
I use them and quite happy.
HTH,
Brian
DB sensitivity between different drives matthias125 Multi-Way 9 22nd October 2012 08:04 AM
96 dB G R tweeter otto88 Multi-Way 2 3rd March 2010 12:15 PM
Sensitivity dB Calculations 69stingray Multi-Way 4 5th July 2007 12:25 AM
change tweeter db? need help hyl2369 Multi-Way 8 25th April 2005 07:42 PM
-14 dB tweeter attenuation ? kristijan-k Multi-Way 2 20th September 2002 09:22 AM
Copyright 1999-2017 diyAudio
