Denim insulation around top and bottom edge, not very neatly applied:
A dip at 4800hz is indicative of a reflection about 0.7" from the diaphragm. Basically the sound is traveling 0.7", hitting something, then being reflected back into the diaphragm out of phase.
Would it be possible to see if there's something in the way? Or is it simply a reflection off of the radial baffle?
If it's the latter, you might stick a little cone of wood into the throat of the compression driver to scatter the reflection.
- What would happen if I took a 1" exit compression driver...
