Options for paper coaxial with soft dome tweeter? - Page 2 - diyAudio
Old 13th September 2013, 04:21 AM   #11
thanks for the nice link!
Old 13th September 2013, 04:52 AM   #12
Yes, remove dust cap and run wires through pole piece. Just an idea, I don't refer to any specific driver. This one looks pretty good for instance GRS 4FR-8 Full-Range 4-1/2" Speaker Pioneer Type A11EC80-02F 292-434
Old 13th September 2013, 06:07 AM   #13
ScottG is offline ScottG  United States
Originally Posted by noviygera View Post
speakers exist: Boenike Studio 12
AUDIOMANUFACTURE BOENICKE AUDIO Studio 12 STUDIO MONITOR
they question is who makes the drivers and who resells them.
http://www.tb-speaker.com/detail/1230_04/w5-1701s.htm
or..
http://www.tb-speaker.com/detail/1230_04/w6-1530s.htm
..looks more like the latter of the two.
Which is independently measured here:
http://www.hobbyhifiladen.de/Lautspr...1530::901.html
Plus, it seems it's the only place you can purchase it from.. For that kind of money go back to the CEntrance speakers..
perspective is everything
Old 13th September 2013, 08:13 AM   #14
OllBoll is offline OllBoll  Sweden
If it uses a dome tweeter then you'd probably have to get one with a waveguide or where the cone acts as a waveguide since otherwise there probably wouldn't be a smooth transition in directivity.
Or you could buy a normal cone driver with phase plug and then just put a small cone tweeter in front of it and get this result =)
After filters the tweeter has a 12dB/oct acoustical roll-off @ 3 khz and the mid has a 6dB/oct @ 3 khz.
This is a dipole though so might not be as smooth with a monopole.
Old 13th September 2013, 03:25 PM   #15
ScottG,
agreed with your last post.
thanks.
Old 13th September 2013, 03:29 PM   #16
Looks like this is the only option: B&C 5FCX44 5" Professional Coaxial
B&C 5FCX44 5" Professional Coaxial Speaker 70 x 70 8 Ohm 294-5760
or for the 6", FaitalPRO 6HX150
FaitalPRO 6HX150 6" Neodymium Coaxial Driver 8 Ohm 294-1192
thanks for all your input guys!
Old 13th September 2013, 05:03 PM   #17
Actually when you move into pro units with concentric compression drivers you'll have more options, but they aren't soft domes.
http://profesional.beyma.com/ingles/...XIAL%20DRIVERS
Home
Old 13th September 2013, 05:07 PM   #18
ra7 is offline ra7  United States
Tannoy makes some nice coaxials that you can buy as spare parts. All the pros, Beyma, BMS, Radian, B&C have coaxial units.
Old 13th September 2013, 06:53 PM   #19
Yes, the pro stuff. So I guess the non-metal (keytone, polyester, etc.) diaphram would be the closest thing to the soft dome tweeter.
So that leaves me with
Beyma 5CX200Fe -- looks easy enough to crossover
B&C 5FCX44 -- similar crossover idea as beyma
FaitalPro 6HX150
BMS frequency response looks like it's gonna need a notch filter for the coax woofer.
Old 13th September 2013, 07:42 PM   #20
FaitalPro 6HX150
Even the poly diaphragms (and surrounds) don't sound like soft domes.
(..obviously in a general sense they sound alike, but the same is true for metal diaphragms as well.)
-and "metal" doesn't always sound like metal.
As far as being well engineered, the KEF replacement parts that ra7 mentioned are quite likely the very best available within certain excursion/power limitations (..ie. loudness limited). Scroll down and look at Zaph's measurement of the KEF Q100 results:
Zaph|Audio
Also see gornir's measurements of the KEF SP1632:
www.audioexcite.com KEF SP1632
Note that the midbass/midrange portion doesn't have the typical "ringing" (or high q "bell" resonance of most metal diaphragms).
..both are more of the midrange-up variety than midbass, but KEF has some midbass coaxials as well (that are a little larger).
You searched for kef | Speaker ExchangeSpeaker Exchange
Soft Dome Tweeter Coatings Rhydon Multi-Way 15 15th November 2016 06:42 PM
Has there ever been a dome tweeter constructed of paper? River757 Multi-Way 28 7th December 2010 11:30 AM
piezo/soft dome tweeter combination e-side Multi-Way 10 3rd September 2005 08:25 PM
SEAS soft dome tweeter sound very very clear jinkuchi Multi-Way 2 21st March 2005 07:21 PM
Help: Soft dome tweeter pushed in Al Garay Multi-Way 46 8th October 2003 07:45 PM
Copyright 1999-2017 diyAudio
