Hi everyone,
I originally planned to make my mid box with a Q of .51. However, I want to add a 12Db/oct filter to this to make it a 24Db/oct roll off.(high pass). I read here: http://www.snippets.org/filters/crossover.htm That if I want to add a 12Db to the natural roll off, then both slopes shopuld have a Q of .71, to give a combined Q of 0.5 What do you guys think ? - I'm halfway through constructing my boxes, and can adapt what I've done already. Cheers Rob |
#2 |
You have a cascaded filter, with the Q of the drivers 2nd order
roll-off and the Q of the electrical filter. There is no reason why the two Q's have to be the same. However they will combine to form a 4th order alignment. A passive crossover combining with the units Q is very, very difficult due to the units impedance rise at resonance. Using an active crossover its simply a question of reading up on cascaded 2nd order alignments to form 4th order alignments. Your mid unit must a bass/midrange with long throw to utilise its natural in box roll-off. If it has a short throw nearly always it must be crossed over at a higher frequency. |
#3 |
Hi Sreten,
It's an active filter. The reason I am asking is the Q of the bass lowpass is 0.49, so I want to match that to get a 4th order linkwitz-reilly x/o. If I add a 12Db/oct high pass with a Q of .7 to the mids natural roll of, I'd need it to be .7 to match. If I left the box at Q0.5 then I'd have to make my active x/o a Q of 1 ? Would this be feasible ? The mid will be at -3Db at 83Hz (simulated - I've yet to measure it) It's a s-speak 8530K-00 Cheers Rob |
#4 |
How much will the mid enclosure's F3 rise if you make the box smaller to get a Qtc of 0.7? Are you willing to adjust the crossover point?
"A friend will help you move. A really good friend will help you move a body." -Anonymous |
#5 |
I'm sure you can cascade an 2nd order active filter to get your
target alignment using the speaker with a Q of 0.5. I don't know the exact numbers but the Q will be near 1, if depends on the F (if lower Q higher) to get the right phase response for the LR alignment. My maths isn't what it used to be so I can't work out the exact values for you. But I'm sure with the box alignment you can get a LR alignment at one particular frequency by using a 2nd order active filter with a different Q and F. |
#6 |
I'll answer my own question. I plugged the Scan Speak 15W 8530 K's numbers into Win ISD.
The red line is 4.8 liters, Qtc=0.71 The blue line is 11 liters, Qtc=0.51 It looks to me that all you have to do is to make the box smaller.
#7 |
Reducing the box volume is the easiest way to do it.
#8 |
Will that move the crossover frequency upward?
Will what is now the F3 become the F6?
#9 |
For the cascaded Butterworths the Butterworths F3 becomes
the F6 of the Linkwitz/Riley alignment. I'm not sure what F6 you'd get using the 0.5 box alignment with a different 2nd order filter, suspect it would be lower. |
#10 |
Thanks Sreten, Kelticwizard.
Reducing the vol. lowers the x/o freq a bit - the tricky bit is making the -3Db of the x/o match the -3Db of the box. The LR x/o sums at the -6Db point so I'll probably have to experiment a bit to get it bang on. I've just e-mailed John Pomann about a kit to breadboard up my x/o. I've got the ESP boards here to make a pair of 3-ways, but these don't have provision for RF filters or baffle step compensation. As I was building up my mids in 'layers' it means they're practically finished rather than halfway through which is nice cheers Rob edit - sreten replied with the above while I was typing this.. |
| DIY Low Pass and Mid/High Pass (Bass Blocking) Filters | runslikealpaca | Everything Else | 1 | 19th June 2009 10:59 PM |
| Paging Mr. Pass, Mr. Pass pull my finger please. | khundude | Pass Labs | 2 | 5th December 2008 04:11 AM |
| Pass Tharagard A75 vs Pass Aleph 1.2's | daly41k | Pass Labs | 7 | 18th February 2007 03:10 PM |
| Amperes of Pass amps & Pass for ESL | rick57 | Pass Labs | 3 | 4th August 2005 03:28 PM |
| My opinion on Pass Labs and Mr. Pass (Nelson) himself | b_online | Pass Labs | 11 | 21st May 2003 12:39 AM |
| Page generated in 0.13399 seconds (76.63% PHP - 23.37% MySQL) with 11 queries |
