3-way open baffle project - diyAudio
Old 10th September 2013, 07:44 AM   #1
Default 3-way open baffle project
Hello!
I started to buy speakers for OB project that looks like this:
Panel 125/83 cm
Bass: 2x Eminence Alpha 15A
Medium: Monacor SPX-200WP
Tweeter: Monacor DT-300 + WG-300
I really need help with the crossover from them. Waiting and any other suggestions as it is my first project of this kind.
Thank you!
Old 10th September 2013, 09:02 AM   #2
miniDSP 2x8?
Old 10th September 2013, 09:18 AM   #3
Juhazi is offline Juhazi  Finland
Juhazi's Avatar
+++ or 4x10Hd
It is a very very challenging task for passive xo and you need to do many many tweaks during setup! You will 3-4 (sub?) amplifier channels too and lots of nominal power because of poor efficiency - expect 12-18dB loss because of dipole correction.
AINOgradient speaker project
Old 10th September 2013, 09:22 AM   #4
ashok's Avatar
Originally Posted by snake69fast View Post
........ first project of this kind.........
To do this perfectly isn't going to be easy. You will have to do a lot of reading too. You might need to understand all the issues at hand and then implement them and come back when you come across problems. That makes it easier for others to help you.
Look up Tech
There are other threads too with results of various OB builds. Do a search on this web site. All this material will keep you busy for a while I guess !
All the best.
AM
Old 10th September 2013, 10:21 AM   #5
evanc is offline evanc  United States
Location: New Jersey. About 1 hour from NYC and 1 min. from the beach
My set up is similar to what your doing. I use passive crossover for the mid to tweeter, but definitely needed mini dsp for bass...plus a lot of wattage for the bass drivers.
http://www.evancotler.com
Old 27th March 2014, 09:50 PM   #6
Hello! Here are some results "with a little help from my friends" - Jerome69, Pano and Rudolf. Thank you again!
Old 27th March 2014, 09:57 PM   #7
puppet is offline puppet  United States
Very nice. With those three fellas helping you along they must sound as good as they look.
Old 27th March 2014, 11:03 PM   #8
adason is offline adason  United States
adason's Avatar
is there any reason why tweeter and mid are so far apart? usually these should be as close as possible
Old 27th March 2014, 11:15 PM   #9
picowallspeaker's Avatar
And it's screaming
dd-dd-dd-diffraction !
Edit: Oh man ! there's also the "8 shape" lobing helping not to make it happen so consistently
If the graphics of a dipole radiation might superimpose on the picture..
Is there a rear tweeter ?
Old 28th March 2014, 10:47 AM   #10
Originally Posted by picowallspeaker View Post
And it's screaming
Not yet!
In fact affter finished my third attempt to build this OB (the one in the pictures) everybody (family, friends) seems to be really impressed. Now after 3 month of listening I know what I want to improve: the mid and the tweeter. When I say that I want to improve them it is not because they sound bad. It is because I want more. So I am open to any advise/help.
Thank you all!
open baffle project sqrivi Full Range 58 25th July 2014 03:25 PM
Need help for my first Open Baffle project anilva Multi-Way 8 22nd January 2010 12:00 AM
First open baffle project Moondog55 Multi-Way 18 10th August 2008 04:35 AM
open baffle project mastarecoil Full Range 25 29th November 2007 05:08 AM
another Open Baffle project Tomac Multi-Way 1 14th September 2006 09:11 AM
Copyright ©1999-2017 diyAudio
