hi all
I,m just trying to nut out the crossovers in my new at15 and am slightly confused at the values
the high section has a .2mh(measured value) inductor connected between a 15uf and 5 uf cap
the mid has a .9mh inductor (measured value) and a 7uf cap and 3.3ohm resistor
crossover points are supposedly 400 and 3000
the above are for the mid and high only as the bass driver is run fullrange with a natural rolloff of 500hz
I,m wanting to fit new caps and resistors but the above values don't seem to work in any crossover calculators I can find
sheafer
sheafer
