Waveguide for XT25
Waveguide for XT25
Old 10th September 2013, 11:40 PM   #21
MisterTwister is offline MisterTwister  Tibet
I think you overvalue importance of waveguides shapes. You can choose any waveguide you like, choose whichever is prettier. Jay, as long as waveguide does not resonate, I don't think it's length matters. If waveguide creates additional peaks in tweeters impedance, then there is a problem. Something like this probably is not suitable for a tweeter. PRV Audio WG 14-25 45x45 ABS Waveguide 1-3/8"-18 294-2841
Old 11th September 2013, 04:34 AM   #22
SpinMonster is offline SpinMonster  United States
Originally Posted by Face View Post
His 8" waveguide seems to be good down to 1500hz.
https://picasaweb.google.com/1016322...1?noredirect=1
acoustic waveguides
The eliptical guide for the XT25 was recently redone. The eliptical is 8.5 or so wide.
The black line is bare. Its lifting even at 1200.
https://picasaweb.google.com/1016322...26940381052322
Old 11th September 2013, 11:56 AM   #23
pjblakey is offline pjblakey  United States
Default cherry waveguides
I found a profile on Zaph Audio website for a 6.5" waveguide and turned a couple yesterday. I made the overall diameter 7" by adding a 1/2" edge to the profile.
Some people think the later XT25 faceplates are glued to the tweeter body. Mine aren't. After removing the 3 screws that attach the faceplate, the separation of the faceplate required carefully inserting a sharp knife at the joint and the plate slowly separates.
Here are 3 pics, one shows the small bevel required to closely fit the face of the XT25. This detail came from Troels' website. I now need to make a couple of wood plates to be located at the back of the tweeter to secure them to the WG.
Test assembly will have to wait until next week.
Peter
Old 11th September 2013, 02:53 PM   #24
Juhazi is offline Juhazi  Finland
Juhazi's Avatar
Beautiful! Well done!
AINOgradient speaker project
Old 11th September 2013, 04:59 PM   #25
chazdrumzalot is offline chazdrumzalot  United States
Jealous. Wish mine looked like that.
Then again, what do I know?
Old 11th September 2013, 07:22 PM   #26
Dave Pellegrene's wave guides cover the outside surround ring. He says it improves measurement.
Easy mounting system just uses 3 supplied posts
Tighten down the nuts. I used a silicone sealer to ensure an air tight fit.
Horizontal dispersion is of a 8" wave guide, vertical is as if it was a 5.5" WG. Sitting on the floor and standing on my couch has no fall if in highs. There is no sweet spot in the room. Dispersion even at 60 degrees off axis is near perfect compared to the bare tweeter. Wave guides also time align the driver. If there is a down side to WG's I dont see it. I see no advantage to a round WG. Elliptical allows a closer spacing to the midbass and thus a higher allowable cross freq if you need it. Dave are $35 each and make for a $70 total per tweeter with state of the art performance. They have lower distortion down low with a cap than any bare tweeter, play 10db louder than bare, and cost so little with perfect dispersion anywhere in the room.
The double mag version of the XT25's are lower ditortion, more efficient, and only cost a dollar more.
The wood ones above are beautiful.
Old 12th September 2013, 12:48 AM   #27
crispycircuit is offline crispycircuit  United States
Thx for the pics. I'm gonna have to try these or copy someones designs. It's surprizing the talent we have this forum.... I'm still looking for my talent....
The stuff you don't know always humbles us.........
Old 12th September 2013, 02:38 AM   #28
Michael Chua is offline Michael Chua  United States
Michael Chua's Avatar
This may help. I just ran some test with Pellegrene's 6.5"x4.5" Elliptical Waveguide and the XT25TG30.
Mic at 1 meter, 5ms window and 1/12 oct smoothing.
No crossover, Short Sine Sweep with Bass removed.
Pretty impressive horizontal dispersion all the way up to 75 degrees off axis.
ampslab
Old 12th September 2013, 06:11 AM   #29
I can stand anywhere in my 21 x 21 foot room and there is no change in dispersion. Its the ultimate party speaker that sounds the same everywhere. The cross is at 1600 so the midbass isn't beaming either.
Old 12th September 2013, 06:12 AM   #30
Copy mine
http://www.diyaudio.com/forums/multi...lots-pics.html
Waveguide for XT25Hide this!Advertise here!
xt25 and ?? - in a bookshelf merbert Multi-Way 2 18th January 2011 09:57 AM
Dipole XT25 thunk303 Multi-Way 6 26th September 2010 01:11 AM
xt25 in 12in waveguide experiment MisterTwister Multi-Way 65 23rd July 2010 06:08 PM
Vifa XT25 Jonasz Multi-Way 30 19th January 2007 05:18 AM
XT25? Yes, but which one...? roibm Multi-Way 6 28th May 2004 06:29 PM
