Explain: Slotted Woofers - see video - diyAudio
Old 5th September 2013, 11:35 PM   #1
Default Explain: Slotted Woofers - see video
Here is a link to a video of some Aurum Quadral High End Platinum speakers (or perhaps Titan models) -
AurumQuadral High End 2011 Teil 1 - YouTube
I'm confused by the fact that the only woofers are set back from a slotted front.
Can anyone explain the design concept and logic behind this choice?
I'm just curious as it is an uncommon speaker design.
Steve/bluewizard
Old 6th September 2013, 12:59 AM   #2
OllBoll is offline OllBoll  Sweden
I'd say the reason is that it looks impressive, and most non pro high end speakers are mostly art.
Old 6th September 2013, 01:13 AM   #3
taloyd is offline taloyd  United States
Talking Amen
That is an economy of words, a generous helping of snark, and a breath of fresh air - all at the same time! (I totally agree, by the way.)
cheers,
-Tal
Last edited by taloyd; 6th September 2013 at 01:27 AM. Reason: clarity, brevity, adieu
Old 6th September 2013, 01:28 AM   #4
Default Isn't the basic idea to...
Steve/bluewizard
... create a low pass filter using the volume of air and the reduced slot area?
Old 6th September 2013, 01:44 AM   #5
Greebster's Avatar
Looks more like a tapped horn of sorts eg the port is wrapped around the edges of the woofers. MAYBE
Old 6th September 2013, 02:19 AM   #6
Default Are these not otherwise...
...conventional rear ported designs?
Old 6th September 2013, 03:24 AM   #7
So, you think this is pure show?
Also, could you expand on the idea that this slot is something of a low pass filter?
Thanks for the responses.
This isn't quite the same speaker, but it gives you an idea of the price range we are dealing with -
Quadral Aurum Vulkan VIII (Pair) at Audio Affair
I suspect the speakers in the Video are more expensive, though hard to tell.
Steve/bluewizard
Old 6th September 2013, 06:10 AM   #8
Greebster's Avatar
The slot the woofers are within is the port
Old 6th September 2013, 06:23 AM   #9
Greebster's Avatar
Tapped horns exist all over the place. When done properly act as a bandpass.
Search button is there for a reason
Steve/bluewizard
I would think the other way around.
They also may be slot loaded open baffle
Nelson Pass: The Slot Loaded Open Baffle Project
Would suggest reading from the beginning, but skip to the last page for a couple ideas that can be done... Nelson Pass: The Slot Loaded Open Baffle Project
Old 6th September 2013, 07:32 AM   #10
Send a message via MSN to sq225917 Send a message via Skype™ to sq225917
Not sure of the concept behind it but their entire range of speakers sounds better than an awful lot of the competition at the price. So they must be doing something right, despite the ugly looks.
Paradise Pre-reg PSU PCBs
Is this sub TL or Slotted Port? buck1138 Subwoofers 1 17th June 2011 09:34 PM
Question regarding Karlson-slotted phase plugs IG81 Full Range 0 24th August 2010 08:01 PM
FR125 MLTL slotted port question valleyman Full Range 7 17th September 2008 04:47 PM
Karlson-slotted pipes PeteMcK Multi-Way 6 23rd June 2004 10:10 PM
Slotted vent calculation? G Multi-Way 13 11th April 2003 05:56 AM
Copyright 1999-2017 diyAudio
