Synergy Horns. No drawbacks, no issues? - Page 30 - diyAudio
Old 18th September 2013, 10:08 PM   #291
Model T's had phase issues with roads I would imagine. I'll bet the people in the horse business were quick to point them out. Eventually though they just went on ahead and fixed the roads instead of slowing down the cars. That Danley design sure looks like the new vehicle, they will fix the road.
I am The Audio Infidel..... I don't even tolerate my own BS.
Old 19th September 2013, 07:25 AM   #292
KSTR is offline KSTR  Germany
KSTR's Avatar
Originally Posted by Okv View Post
Even at a relatively close 1m and with high directivity in a well damped room, the phase response will be affected by reflections so that it really does not show the phase from the speaker itself - typical phase response measured in-room are usually useless due to this, as the difference is so large that the curves does not represent anything close to what the speaker response really is.
That is the typical case, and may or may not be applicable for this specific measurement, I am sure Danley knows exactly the answer for that.
It is not applicable, as you would have seen yourself if you had inspected the pulse's decay.
For a single reflection to alter the unsmoothed phase significantly it must be 10dB or less down from the main pulse. Again you could have tested that yourself by analysing a dirac and a copy of it, say, 10ms later and -10dB down, before making broad generalizations.
As for myself, I've compared anechoic pulses of speakers on infinite baffle extensions with in-room measurements (maximised distances to walls, of course) and when it comes to extracting phase -- for reverse phase correction that I often apply to get minphase or even linphase behaviour -- there is no significant difference, notably after proper (frequency dependant) windowing, that's why it is used.
Your statement is true, though, for very strong modal effects at very low frequencies.
Old 19th September 2013, 08:01 AM   #293
Oh wow!
What a great document, this is http://www.pispeakers.com/Pi_Speakers_Info.pdf and what a business plan too, just tell the truth! Lay it out plainly, don't brag and the item just might sell itself. I'm sure most of you all have already read this but for those of us that haven't, Wow again! Do yourself a huge-huge-huge favor and really, really read this. Then read it again. Why is it relevant to this thread?
1. Because to my mind it completely totally and with finality illustrates the issues and therefore whether it was Mr. P's intention or not, it shows that the Synergy horn is a design with potential to solve almost all of the troubling crossover/driver related speaker problems.
2. Guys like Klipsch, Keele etc already knew all of the issues and presented the best compromises possible with the drivers and economics of the time, little has changed all still totally relevant, but yes our conventional speakers are now "computer vitamin crossover enriched"
How refreshing this little paper is, reminds me of PWK's stuff but with even less BS! Damn! just when I was getting all jaded and crap it turns out that one can still survive by just being honest as you can and seeing if your product fits in that "truth" window.
I really like this completely straightforward approach, it seems very similar to that dude's from Hope Ark. (No not that one, the non BS speaker guy) Mr. Danley sure seems to fit this mold too! In any event what a great paper! It's just about one stop shopping for speaker "understandment" and condenses the vast majority of what I have gleaned from hanging about here into a few minutes. Great to say the least. Honest to say the least. No obfuscation to say the least. Ok I've said more than the least.....see link above
Old 19th September 2013, 10:04 PM   #294
Okv is offline Okv  Norway
I just checked, and indeed even indoor measurements can provide usable phase information, provided the window is set properly short.
Comparing measurements I know are more reliable to some taken in reflective surroundings I see the phase responses match.
When the reflected sound becomes large enough compared to the direct sound, the phase will shift all over the place because the measured sound will be delayed, due to summation of the direct and the reflected, where the reflected will be delayed.
The problem is, as I see it, that it may be difficult to make sure that the phase response derived from the measurement really is that of the speaker itself, not affected by reflections.
Old 19th September 2013, 10:21 PM   #295
Patrick Bateman's Avatar
Originally Posted by peteleoni View Post
Oh wow!
The whole reason that I learned about Unity horns was because I had a job at a dotcom that was circling the drain at the tail end of the tech crash. This was in 2001. We all knew the company was toast, but it took close to a year for it to die. I spent that time learning about the Unity, and the MOST vocal person criticizing it was the person who wrote that paper!
Old 19th September 2013, 11:43 PM   #296
Funny, because it sure makes a case for the Synergy. That paper must be pure torture for people trying to market speakers via pseudo-science. That has got to be the most down to earth and honest white I've seen. I can't seem to find an ounce of self serving fluff in there.
Old 19th September 2013, 11:55 PM   #297
Banned
peteleoni, do you own and listen to synergy speakers?
Old 20th September 2013, 12:25 AM   #298
Pano is offline Pano  United States
Pano's Avatar
Pete - I take it you haven't met Wayne?
Old 20th September 2013, 02:19 AM   #299
Send a message via AIM to SpeakerScott Send a message via MSN to SpeakerScott Send a message via Yahoo to SpeakerScott
I'm guessing he hasn't...
Old 20th September 2013, 02:51 AM   #300
No I haven't met Wayne P. Going by this paper and site alone. And no, not heard the Synergies yet either, I did hear Unities and that got me cranked into this. Obviously I have heard lots of the takes on two ways with compression drivers and really really good crossovers on really really new horns though, had every JBL studio monitor like that imaginable at some point, heard lots of exceptional "Zilch" type speakers lately will assume Geddes is the best of them, but this in nor new for audio pros. No I don't know all of the speaker personalities yet. Just a few. Met Keele though. Now there is a trip!!!!
Spreadsheet to design your own Synergy (or more simple conical) horns bwaslo Multi-Way 2 5th March 2014 08:24 PM
benefits and drawbacks of waveguides Professor smith Multi-Way 68 25th June 2012 06:43 PM
Synergy Horns johnB23 Full Range 1 2nd June 2012 06:52 PM
Drawbacks of Parafeed? dsavitsk Tubes / Valves 17 19th October 2006 09:08 PM
Line Array Drawbacks? MrPin Multi-Way 2 5th February 2006 08:51 PM
Copyright 1999-2017 diyAudio
