Can a 2" x 4" port be done as... Can a 2" x 4" port be done as... - diyAudio
Old 1st September 2013, 05:57 PM   #1
makingmoney is offline makingmoney  United States
Default Can a 2" x 4" port be done as...
a number of 1/2" x 3/4"deep holes so that the total volume of the smaller holes combined equals the same volume as a 2" x 4" port. (.206L or .007 ft3)?
Pretend the -3db is 50hz for the box and driver combo.
Any sonic penalties? Port noise?
Old 2nd September 2013, 12:04 PM   #2
fpitas is offline fpitas  United States
If you're asking about using multiple small ports vs. one large port, the effect is that port Q will be lower because of the greater peripheral surface area.
Can a 2" x 4" port be done as...Hide this!Advertise here!
XITEL MD PORT DG2 . " USB TO OPTIC TOSLINK " WhiteRhino Digital Line Level 6 11th July 2015 10:43 PM
Sony "digital media port" eleakist Digital Line Level 4 16th June 2009 01:53 PM
"Serial Port Complete" Act II jackinnj Everything Else 0 5th March 2008 01:00 PM
30" long 4" Precision Port PoorboyMike Subwoofers 4 11th May 2007 12:01 PM
4"x8" Port = two 4"x4" Ports for MLTL??? More Complex??? OTMOPO3OK Full Range 2 17th January 2005 03:58 PM
Copyright ©1999-2017 diyAudio
