TDL RTL3 upgrade
TDL RTL3 upgrade
Old 1st September 2013, 08:47 PM   #11
system7 is offline system7  United Kingdom
system7's Avatar
Bob, you should be able to tell polypropylene from paper cones just by looking at them and touching them. Plastic is shiny stuff like plastic detergent bottles, paper is, well, cardboardy like your cornflake packet.
We are still stuck at the starting gate here...
Photos might help.
And, yes, Mr. Marley is right, price is no indication of quality really. You can do a lot with a good crossover. My favourite Visaton TW 70 cone tweeter costs just 10.
Best Regards from Steve in Portsmouth, UK.
Old 1st September 2013, 09:32 PM   #12
shedlock is offline shedlock  United Kingdom
shedlock's Avatar
Ah but what if the cardboard is coated with plastic .
My considered opinion is that they're the Visatons ...they're the same as these in the pik (but my cabinets are oak finish).
Having read up a bit this evening on anything I could find, it would seem there are differing opinions as to whether these are variants of the Visaton W170 S or the WS 17 E drivers. On the off chance that I might get a reply, I've emailed Visaton to ask if they can clarify, but I think I'll go ahead with the Clou idea anyway, using these drivers, and see how it turns out .
Old 1st September 2013, 11:37 PM   #13
system7's Avatar
You haven't a clue really! They could be Elac units too.
Now have a look at the back of the cones, they won't be coated with anything. Polypropylene is really quite distinctive shiny smooth stuff. Not as scratchy sounding as paper.
Old 2nd September 2013, 12:13 AM   #14
shedlock's Avatar
Now here's a thing ...I've managed to locate specs for both the original RTL3s with the Monacor squared-off-edge drivers, and the special edition RTL3s (like mine), and both specify a polypropylene cone. The difference in the specs is the tweeter, which is 19mm for the early version, and 25mm for the special edition, also the frequency range goes down to 30hz for the latter, as opposed to 35hz.
Although not that relevant to this, I'm pretty sure the tweeters are Eltax item 03045.
I haven't got the speakers with me at the moment, they're in the workshop, but I'll take the drivers out first thing tomorrow and see if that sheds any light on things.
Old 2nd September 2013, 12:41 AM   #15
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
TDL RTL3 upgrade
I's suggest that with these speakers, cleaning up the XOs, stuffening the cabinet, oprimizing damping, and driver tweaks would be as far as you want to go. All relatively low material costs, but lots of research & hand's on. Learn without spencing much.
Pictures of the drivers out of the box, the XO, and a few inside shots of the box would be helpful
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 2nd September 2013, 09:51 AM   #16
shedlock's Avatar
Well, they're definitely polypropylene cones. No manufacturer's name (that would be too easy) but there is this on them... 172-NS-08.
There didn't seem a lot of point in photographing the crossovers, as without mullering them, all you can see is the underside of the circuit board ...the components are hidden between that and the the terminal plate thing.
I have to say, I'm amazed that these unimposing, even feeble, looking drivers manage to produce the amount of bass they do in those cabinets.
Old 2nd September 2013, 06:42 PM   #17
system7's Avatar
That's good stuff, Bob. I think those are ELAC units. Probably similar to the 172 NS 05 which has a 34mm voice coil. Probably 7 ohms DC resistance if nominal 8 ohms, but worth measuring.
I get a Vas around 15L and a Qts around 0.44 and Fs 32Hz and 87dB sensitivity. Closed box drivers really. Will work in 10-20L if I haven't lost my touch.
Your crossover may be similar to Vikash's one on the bass part. But you have a 25mm tweeter rather than the feeble 19mm jobbie. What tweeter cutout and motor hole do you have? 94mm or maybe 104mm outer diameter?
I'd have to model that overheating 10R bass shunt to figure out a better way of doing it. But progress.
Old 2nd September 2013, 08:58 PM   #18
shedlock's Avatar
Well a swift google of Elac 172 NS 08 and (ta-da) this pops up quick as you like! So the whole Visaton thing's just a massive red herring ...amazing how there's so much written out there pointing to them.
The tweeter hole is 79mm with the recess at 100mm, and (if you need it) the hole for the driver is 150mm.
Bob
Old 2nd September 2013, 11:21 PM   #19
shedlock's Avatar
ps ...has your 'System 7' anything to do with Steve Hillage's System 7?
Old 3rd September 2013, 11:07 AM   #20
shedlock's Avatar
I've spent a bit of time this morning trawling what I could find on the net in the hope of finding a scheme specifically for the 'special edition' crossover. The only thing I've been able to discern for sure is that what made them 'special edition' was an upgraded crossover and tweeter (as well as better quality internal cabling ...oh, and gold coloured screws for the drivers!).
I haven't mentioned that I also have a pair of RTL1s. These I bought in the mid nineties, if I remember correctly, and it was the fact that I liked these so much that led me to eventually get hold of their bigger brothers when I was looking for a new pair of floorstanders years later. They're not badged as SE, but have the same drivers and overall cosmetic appearance ...rounded bottoms to speaker grills etc.
I know the crossovers are going to be different, only having the one woofer, but I would be prepared to risk wrecking these crossovers to see how they're constructed if it could be helpful. I can't get hold of them for a day or so, as they're currently in storage following a recent move, when I do I'll check to see if they have the same tweeters as the SEs.
I did find this listing/info on hebay (of all places) which I think might be worth a link.
TDL RTL3 upgradeHide this!Advertise here!
Rehousing speaker - TDL RTL3 Vikash Multi-Way 81 25th June 2016 06:28 AM
TDL RTL3 Blown Mid Bass unit Fanuc Multi-Way 12 9th February 2016 06:06 PM
TDL RTL3's -Advice needed! bertieduff Multi-Way 17 14th September 2010 04:14 PM
TDL Studio 1 Paul Smith Multi-Way 3 22nd January 2005 11:05 AM
