cylinder enclosure- is basket too close to inside baffle? cylinder enclosure- is basket too close to inside baffle? - diyAudio
Old 26th August 2013, 11:36 PM   #1
osd1 is offline osd1  Canada
Default cylinder enclosure- is basket too close to inside baffle?
Hey now.
I am about to start building a speaker enclosure. I have a 6" midwoofer and I want to do something a little different. I was thinking of making a cylinder enclosure for the midwoofer, then one for the tweeter.
The basket is about 5.75" so I was going to make the from baffle with a 5.75" cutout inside of a 9" circle. After that I was going to increase the size of the cutout hole of the 9" circle, making it 8."
Is that an ok idea? I am not going to run into any problems with standing waves am I? Also, is it ok if the basket is 1-1/8" away from the inside baffle all the way around?
I have no problems building it as i am a woodworker, its just the sound side of things I have questions on.
Thanks in advance
Old 27th August 2013, 10:13 AM   #2
AllenB is offline AllenB  Australia
It's a little hard to say but easy enough to take precautions. Can you chamfer the inside of the inner baffle so that it doesn't restrict the rearward flow? Make sure the space behind the driver doesn't seem small compared to the cone unless you are designing it to be that way, and don't overstuff it for the same reason.
Try not to reflect any sound from nearby walls directly back at the driver. This is not easy with a curved rear panel and, together with room for stuffing, might be one more reason to have just a little more room behind the driver.
Old 27th August 2013, 03:00 PM   #3
badman is offline badman  United States
Custom Title
badman's Avatar
Make sure the basket can "breathe" as stated, and after 5.75", 8" should be plenty, so long as you don't impede airflow with fluffy stuffing around the driver. Lining the walls with felt may be worthwhile depending on the frequencies of concern.
"The dawn of Bose created the "Man Cave" and reduced testoterone levels worldwide by 18.5 per cent" Peteleoni
Old 27th August 2013, 07:06 PM   #4
I can def chamfer inside the cutout of the woofer. This is for a 6" midrange in a 3 way. I am not gonna be sure what the crossover point is gonna be for the 6". There will be an 8" driver for the bass operations.
So the SB23NRX 8" will be in a regular rectangle enclosure. On top of it, the SB 17NRX 6" will be in its own enclosure, a cylinder one. Above that will be a Morel tweeter, in its own cylinder enclosure.
So far I have a depth of 8.25" interior measurement. That, unstuffed, will give me a volume of .23 ft3 including driver displacement. Madisound recommends .25ft3 for the SB 6" woofer but doesn't say how much stuffng is needed.
Old 27th August 2013, 07:08 PM   #5
I am not quite sure exactly what frequencies in specific are gonna be sent to this driver. I won't know till I get a crossover design from the person who is doing it. I can tell you that its probably going to be an upper midbass and midrange.
Old 27th August 2013, 10:18 PM   #6
Custom Title
badman's Avatar
Then probably a 1/2" layer of felt, for a midbass, is a wise idea- won't block the backwave but will soak up some early reflections.
Old 28th August 2013, 01:22 AM   #7
do i want to block the back wave?
Old 28th August 2013, 09:57 AM   #8
It looks as if you might end up choosing a crossover as far as 1kHz - 4kHz??
It's not a bad idea to have your stuffing distributed over say, half of the cabinet depth. This ensures that it will work more consistently over a range of frequencies.
You'll then want to adjust the density of the material, which you could do while listening.
Old 28th August 2013, 05:08 PM   #9
Greebster is offline Greebster  United States
Greebster's Avatar
Cross the 6" over at around 2.5-2.7kHz for best off axis power response.
Old 29th August 2013, 02:46 PM   #10
Custom Title
badman's Avatar
No. You definitely don't want to reflect sound back towards the cone- that's why lining the walls around the driver with felt, rather than using stuffing, is a good idea. Stuffing's okay too but takes more care, you'd want it quite loose, and keeping it from interfering with cone motion can be challenging (something like a "sock" will add it's own reflective and absorbtive properties to the mix)
cylinder enclosure- is basket too close to inside baffle?Hide this!Advertise here!
Chamfer inside a subwoofer baffle?? Kooshball Subwoofers 2 13th January 2013 02:58 AM
Sub enclosure inside a Camphor Chest qguy Subwoofers 6 11th June 2011 01:48 AM
Effect of mounting driver on the inside of a baffle? Theli Multi-Way 24 3rd November 2009 04:14 PM
Open baffle VERY close to back wall? Fast1one Multi-Way 6 4th April 2009 07:01 PM
NAD power lamps inside the enclosure destroyer X Solid State 13 9th October 2008 04:27 PM
Copyright ©1999-2017 diyAudio
