Localisation of very low frequencies sounds - Page 3 - diyAudio
Old 29th August 2013, 01:21 PM   #21
Greebster's Avatar
But if the graph is offset by 20 dB to fit the scale this should be subtracted from the curve
Old 29th August 2013, 01:52 PM   #22
Pano is offline Pano  United States
Pano's Avatar
I see the distortion as highest at 70Hz, being approximately -9dB. But that graph looks like a plain baffle measurement of the driver, not the driver in a box. Or maybe a small, sealed box.
Take the Speaker Voltage Test!
planet10 needs your help: Let's help Ruth and Dave
Old 29th August 2013, 03:56 PM   #23
Banned
Ergo gaetan8888 would need to measure distortion of his box at the SPL he is doing the test.
Old 29th August 2013, 06:58 PM   #24
Greebster's Avatar
Too true, requires reality check
Old 29th August 2013, 10:11 PM   #25
Pano's Avatar
Yes, it would be best to see measurements of the driver in a box.
But don't forget that there are two separate issues here:
  1. Can you hear the direction of a pure tone below a certain frequency? (no distortion)
  2. Can you hear the location of the typical subwoofer low passed below a certain frequency with its attendant normal distortion?
I think item number 2 is the more important, as that's what we will encounter in real usage.
Old 29th August 2013, 10:43 PM   #26
The dark black line is phase, guys. It says it's a 10L box.
Old 29th August 2013, 11:34 PM   #27
Greebster's Avatar
Wasn't the line I was comparing to.
Old 2nd September 2013, 02:41 AM   #28
Pano's Avatar
So it does! Thanks for that.
Originally Posted by Pano View Post
...maybe a small, sealed box.
Yep. 10L is small.
Old 2nd September 2013, 03:31 AM   #29
0.5% distortion at 10hz? I want that speaker!!! (BTW I wouldn't be able to hear it anyway)
given choice of low screen voltage or low bias which sounds better or is it equal ryuji Tubes / Valves 2 23rd March 2012 01:32 PM
subwoofer noise at low frequencies justinc Subwoofers 7 3rd March 2010 12:05 AM
biamp used only to drive low frequencies kdlsrinu Solid State 5 25th August 2005 10:43 AM
Low dist at high frequencies Pan Solid State 3 11th December 2004 11:31 PM
Protecting Tweeter from low frequencies... wigginjs Multi-Way 10 29th November 2004 02:24 AM
Copyright 1999-2017 diyAudio
