My first wave guide speaker....lots of pics
Old 27th August 2013, 12:50 PM   #81
Juhazi is offline Juhazi  Finland
Juhazi's Avatar
Perhaps it was not fair to compare CD2 to CD3.5H
But here are Fountek's own datasheet graphs of dispersion of CD3.0 and CD3.5.
Any way - I am pleased with 3.5H and it has very wide listening angle! My measurements show that contrary to round/ellipsoid waveguides of Dave and many others - around 15kHz dispersion holds continuity better. Effect of horn termination/edge? It is almost a rule to see a dip at on-axis response of a waveguide tweeter at 15kHz - and see it disappear at 15¤ or more. This dip on-axis is perhaps the reason why many disregard waveguides and coaxials, so sad!
File Type: png CD30 vs 35H datasheet disp hor vert.png (179.7 KB, 702 views)
AINOgradient speaker project
Old 27th August 2013, 08:49 PM   #82
SpinMonster is offline SpinMonster  United States
You cant hear a dip at 15k and above.
The dispersion of all ribbons is fine in the horizontal plane because the width of a ribbon is typically 3/4" or less.
Its the vertical dispersion thats bad.
Old 2nd September 2013, 09:07 AM   #83
I always had the misconception that early reflections in a horn would ruin imaging but these speakers are pinpoint accurate with imaging. They definitely get horn instruments right. I was worried about colorations but they sound so natural. More tweeters should have horn loading. I moved the cross over down to 1600hz. Its so much cleaner than a bare Xt25. I have searched and seen that some have used 8-10" wave guides with the XT25 down to 1200hz with them. It solves the high freq issues in so many mid bass drivers.
I moved around the room with the mic for the analyzer and there is no major drop off and they maintain the flat response everywhere. Its got to be the best party speaker I've built. I'm very happy with the results. I thought there would be more of a fall off in the top end of the midbass but I guess 1600-1700 sustains off axis response well.
Dave's wave guides are likely my best audio purchase in years. $70 bucks
Old 2nd September 2013, 09:12 AM   #84
Anyone have any input on the sound quality of an XT25 with a wave guide vs a BMS 4550 and a seos 10 or 12 wave guide? I can flatten frequency response. I'm just curious about quality of sound as far as distortion or resonances that cant be fixed. As an example of what I mean, some say the Selenium 220 has a tizzy sound to it.
I figure the pro driver would be the last word in transients and clean high output sound being that it would be playing at a fraction of its output capability even at high volume in a home application.
Old 17th September 2013, 08:11 PM   #85
critofur is offline critofur  United States
critofur's Avatar
Send a message via AIM to critofur Send a message via MSN to critofur Send a message via Yahoo to critofur
Originally Posted by Dave Pellegrene View Post
... This started as an RS150/ XT25TG30 combo for the top of a three way. I ended up switching out to the ER18 and the LD25X. Although twice the money IMO i think well worth it...
If Zaph's distortion measurements are to be trusted (and I think they are) then there really would seem to be zero benefit to trying to find another tweeter with lower distortion - the XT25 + waveguide combo is already absurdly low once a crossover is added (better than all the $200 - $300 or even higher non-wg tweeters I've seen).
And I've seen enough comments about the XT25's phase plug providing some benefit in waveguide applications that I think you might even be taking a step down, not up, moving to the LD25X from the XT25?
That's for a pair?
Critofur
http://www.ohmspeakers.com <- all the folks here are my friends
Old 17th September 2013, 09:36 PM   #86
No bare tweeter matches its distortion with a cap because it lower all forms of distortion by killing whats going on lower in frequency.
Yes, its $70 a pair and a bargain for not having to deal with hack mounting systems. It also includes shipping in that 70.
Old 18th September 2013, 09:42 AM   #87
Dave Pellegrene is offline Dave Pellegrene  United States
Dave Pellegrene's Avatar
I had both set up with a 6.5" somewhat elliptical waveguide crossed around 2kHz I believe. I thought they both sounded better crossed at this point rather then lower although the polars looked as good lower. I just thought the LD25X sounded quit a bit more detailed. I switched to the ER18 after the tweeter switch and I preferred it. Maybe 2kHz was to high to cross the RS150. This is just my opinion listening to one unfinished speaker but I was convinced enough to move forward with the LD25X/ ER18 combo. Although I still haven't got back to finishing the second speaker so I really haven't moved forward. I thinks it's a Moot point anyway since the LD25X is no longer available with the removable faceplate and that's what was needed to fit my guide to.
Dave
That's for a pair?
Old 11th October 2013, 03:07 PM   #88
critofur's Avatar
Waterfall plots / distortion didn't look so good with the 3.5H from the measurements from the only person that I've seen post such measurements, could you post those measurements? I'd like to see a second opinion. Maybe I'll try the 3.5H (I already have some Vifa XT25 tweeters and the 6.5 inch waveguides, but I've yet to machine them to fit...) I was also thinking about the D.P. waveguides. $70 for a pair of the waveguides seems a bit too expensive - but, since I aready have the XT25 tweeters, I suppose it is less than buying a pair of 3.5H...
Critofur
Old 11th October 2013, 11:11 PM   #89
I usually have pretty good luck removing that dip. It really depends on the tweeter. Sometimes there is no dip at all. Other times I can remove it with a step between the adapter plate and the guide. Sometimes a phase plug works but usually it creates other problems. I've been able to remove it on axis then have it show up off axis. As I said it just depends on the tweeter and I'm not sure why it happens. It does seem to have to do with the throat size. If I reduce down so the throat is the size of the dome that will sometimes remove it.
Dave
Old 13th October 2013, 06:12 PM   #90
Juhazi's Avatar
critofur, my Fountek NeoCD3.5H is nude and it is a part of my AINOgradient. I have lots of measurements of it. Here outdoor csd and distortion measured at 150cm. Xo is done by minidsp and if I remember right it is LR2 at3000Hz or like here. The directivity is 10¤ intervals 6ms gating, distance 120cm, xo at 3300Hz LR4.
I believe this is as good as it can be! The horn helps the speaker to maintain low distortion and I have tested it wit 2200Hz LR4 without any problems with distortion, but of course the there is some. A wider frame would make directivity worse I guess or at leas make more diffractions. Here the frame is the driver's own frame w=98mm. The baffle thickness is 12mm+4mm from the driver.
My first wave guide speaker....lots of picsHide this!Advertise here!
Horn Extender/Wave-guide for TH weltersys Subwoofers 166 15th March 2018 01:11 PM
Tweeter CD wave guide Audiodidakt Multi-Way 4 27th December 2012 11:54 AM
Wave Guide Website Up and Running Dave Pellegrene Multi-Way 3 28th October 2012 11:10 PM
guitar speaker horn/wave guide? pzung Full Range 1 30th January 2010 11:53 PM
what is a wave guide? Joules Multi-Way 7 12th May 2005 02:25 PM
