My first wave guide speaker....lots of pics
Old 27th August 2013, 03:53 AM   #71
Dave Pellegrene is offline Dave Pellegrene  United States
Dave Pellegrene's Avatar
Originally Posted by Beau View Post
https://lh6.googleusercontent.com/-D...horizontal.jpg
Take a look at Daves own plots, at 45 deg the sound is Consistent off axis vs no waveguide.
These measurements are 0, 30, 60 and 90 degree measurements. My goal is to have the guide at least match the 60 degree angle of the flat baffle. Usually from 60-90 degrees the flat baffle holds the top end better. Being I am able to reduce the throat size of the guide to 1" on the XT25 I get boost all the way to 12.5kHz. Between that and the guide depth is only 1.5" the guide does quite a bit better. That is what I've been concentrating on with my guides lately. I like to see from on axis to 90 degrees off axis at 10kHz for there not to be more then a 22-25 db spread.
Dave
Old 27th August 2013, 03:59 AM   #72
Beau is offline Beau
Dave, what happens to the top end when you make the guide deeper, say 2 inches?
Old 27th August 2013, 04:07 AM   #73
The deeper the guide the quicker the top end rolls off off axis. You can pretty much figure when you look at the tweeter off axis in the guide once you can no longer see the dome the top end rolls off quicker. Also on the smaller guides the extra depth will make the walls steeper which will cause more reflections. On an 8" round guide 2" deep is about it with a dome. That is about a 3.9" radius.
I should add IMO.
Dave
Old 27th August 2013, 04:11 AM   #74
Cheers, thats exactly what I needed to know. Will the OT19 have any advantage in an 8"diameter 2" deep guide over an XT25SC90, particularly in the low end?
I know that may be a little vague..
Sorry for the threadjack Spinmonster.
Old 27th August 2013, 04:58 AM   #75
SpinMonster is offline SpinMonster  United States
not a hijack....everyone is learning
Old 27th August 2013, 06:27 AM   #76
Juhazi is offline Juhazi  Finland
Juhazi's Avatar
This is getting more out of line, but as to discussion about wg edges and horns - an example of how Fountek NeoCD3.5H performs. It has a small horn with 1.5cm flat edges. I use it as nude, no frame!
My own outdoor measurements. Violet is nearfiel, others are taken at 1.5m distance (5'), 3ms gating. All with 6.8uF cap in series and LR4 xo at 2500Hz set in minidsp. Not bad at all But distortion rises below 2kHz and we must be careful of not destroying the membrane.
a discussion of it at PE forum Fountek NeoCd3.5H Horn Tweeter
datasheet of NeoCD3.5H http://www.fountek.net/uploadfile/1011/25100645.PDF
AINOgradient speaker project
Old 27th August 2013, 08:25 AM   #77
R.I.P.
re post38
Does anyone have an opinion on whether I am reading the diagrams correctly?
regards Andrew T.
Old 27th August 2013, 08:41 AM   #78
The data sheet shows no loading from the horn other than a big peak over 10K. The idea is to use a big enough WG to load the tweeter so a cap then lowers the distortion while returning the response back to flat. To have lift at 1500 you would need 8-9" of wave guide.
Old 27th August 2013, 10:48 AM   #79
Juhazi's Avatar
The Fountek CD3.5H has internal cap and propably a coil too (impedance dampening) to make it flat on-axis. Basically it is a CD3.0 with a waveguide. If we compare distortion of CD2.0 (Zaph)and 3.5H (PE forum) we can see what the waveguide/horn contributes.
Old 27th August 2013, 11:06 AM   #80
I'm not seeing any drop in distortion. In fact, the F2 looks worse on the 3.5. On a conventional dome, the WG and cap is a 30db drop at 1k for F2.
I'm a fan of Ribbons but it seems its tough to get a clean one. I had the Aurum 3si and made my own ribbons for it. I just couldnt deal with the sweet spot being 12" wide seated on my couch.
My first wave guide speaker....lots of picsHide this!Advertise here!
Horn Extender/Wave-guide for TH weltersys Subwoofers 166 15th March 2018 01:11 PM
Tweeter CD wave guide Audiodidakt Multi-Way 4 27th December 2012 11:54 AM
Wave Guide Website Up and Running Dave Pellegrene Multi-Way 3 28th October 2012 11:10 PM
guitar speaker horn/wave guide? pzung Full Range 1 30th January 2010 11:53 PM
what is a wave guide? Joules Multi-Way 7 12th May 2005 02:25 PM
