JBL D2 dual concentric compression driver
Old 16th August 2013, 08:14 AM   #1
hasselbaink is offline hasselbaink  Denmark
Default JBL D2 dual concentric compression driver
Has anyone tried this driver or listened to it?
JBL-D2
There is a lengthy discussion on the Lansing Heritage forum about the M2 monitor that uses the D2: JBL Master Reference Monitor
I would sure like to know if it is available for purchase.
Best
Kris
Old 16th August 2013, 01:29 PM   #2
1audiohack is offline 1audiohack  United States
1audiohack's Avatar
They are available. They are also used in the VTX series array systems.
Old 18th August 2013, 05:27 AM   #3
ewgrosschris is offline ewgrosschris  United States
Cant say much other than, I think they make a night and day difference in the VTX compared to the Vt4889's. I'd love to see what some forum members can do with these.
Old 18th August 2013, 06:17 AM   #4
NEO Dan is offline NEO Dan  United States
NEO Dan's Avatar
While I can't comment directly on the D2 I do see the 2408H mentioned in the article, I have those and they are pretty amazing. Here is a LOUD three tone distortion sweep at 100w, the cabinet is tuned to ~93Hz. Not bad for a "small" driver IMO. WAY WAY more output capability than needed for domestic HiFi.
Dan
Old 18th August 2013, 06:36 PM   #5
LineSource is offline LineSource  United States
LineSource's Avatar
How low in frequency should a horn directivity pattern go for home audio?
The latest home audio high efficiency options:
coaxial ring radiator compression driver vs.
single Beryllium diaphragm compression driver vs.
Synergy Horn
JBL: two identical annular diaphragms combining in one common exit chamber.
BMS: one large annular midrange diaphragm combining with one ultra light high frequency diaphragm into a common exit chamber
Old 18th August 2013, 07:36 PM   #6
NEO Dan's Avatar
If you are thinking of the speaker as a whole you'll want directivity to extend below the mid hi horn and so the limitation is really in the bass section.
Dan
Old 19th August 2013, 02:19 AM   #7
mayhem13 is offline mayhem13  United States
Had a change to listen to the M2 at an industry event......as I indicated in the JBL horn thread, best speaker I've listened to yet. There's a real magic in that waveguide/driver combo.
Old 19th August 2013, 03:26 AM   #8
LineSource's Avatar
The avsforum has a few threads on using BMS coaxial compression drivers with the "you can buy it now" SEOS 24 waveguide.
just another seos 24 build
Old 19th August 2013, 04:15 AM   #9
NEO Dan's Avatar
You've been able to buy good medium format stuff for quite some time now... For less...
3722/4722 PTWG
I think there should be some distinction between what the M2 is as a system and what a DIY'r can do with the waveguide and compression driver. There is a gap there, and that gap is filled with $$$$ IMO.
Dan
Old 19th August 2013, 09:10 AM   #10
Thanks for the replies guys.
I really would like to see the raw measurements of this driver, both diaphragms, to see how easy/hard this driver is to work with.
BTW, this will be for home use and I would try it on a few different horns as well.
My motivation is that I would very much like to see a driver that combines a large format diaphragm with a tweeter AND sound great at the same time. If we could knock path differences and lobing issues in the head, wouldn't that be fabulous!
PS. Who is selling these? (please provide a link)
Best
Kris
JBL D2 dual concentric compression driverHide this!Advertise here!
JBL D2430K compression driver? Dave Zan Multi-Way 3 1st September 2012 07:28 AM
Compression driver and horn for JBL 3678 saevox Multi-Way 2 18th July 2012 09:41 PM
Matched Pair JBL 2446H Compression Driver (Consec Serial #s) longdrive55 Swap Meet 0 14th July 2009 06:46 PM
Dual concentric? Tony.ca Multi-Way 12 8th November 2004 12:29 AM
Tannoy Dual Concentric Driver Unit PTSOUNDLAB Multi-Way 4 13th March 2004 08:31 PM
