What are some decent drivers for a small/mid size center channel speaker (1 mid,1 tw)
Old 11th December 2003, 11:20 PM   #1
kehi is offline kehi  United States
Default What are some decent drivers for a small/mid size center channel speaker (1 mid,1 tw)
HI, I am planning on constructing a box along these dimensions or something close.
Width- 15"
Height- 8"
Depth- 12"
What I need are a midbass and tweeter combo that would work well ina box of this size. What program/tool can I use to determine what combos will work well together? I already have a Dayton 3000hz crossover that I purchased a while back and plan using it in the build. Has anyone ever seen a center along these built, have a guide? Thanks for all the help and take care
Old 11th December 2003, 11:31 PM   #2
R.I.P.
Tonal integration with your existing front speakers is important.
If you already have a crossover you should use it with the drivers it was designed for.
Your box size indicates that reflex loading will be appropriate for a 6.5" mid/bass unit.
sreten.
Old 12th December 2003, 01:30 AM   #3
If I was to use a 5 1/4" driver how can I determine what the box size should be? Thanks and take care
Old 12th December 2003, 02:45 AM   #4
I am thinking about using This midbass with a bucking magnet for shielding and This tweeter. How can I find out what size box I need in order for this is to a decent center channel speaker. Thanks
Old 12th December 2003, 08:28 AM   #5
R.I.P.
Use winISD freeware to design a simple sealed box.
With a metal cone midbass the crossover MUST be
specifically designed for that unit or will not work.
sreten.
Old 12th December 2003, 12:28 PM   #6
rabbitz is offline rabbitz  Australia
rabbitz's Avatar
Nice combo for a TM centre is Vifa D26NC tweeter and Peerless 5" HDS 850528 woofer. Makes for a nice low profile for a centre.
This is one variation I've done (Vb=11.3 litres).
Old 12th December 2003, 09:11 PM   #7
michael is offline michael  Australia
Send a message via MSN to michael
hey rabbitz, could you post your crossover for that centre. or email it to me, that would really be cool, thanks
Old 13th December 2003, 04:09 PM   #8
rabbitz's Avatar
Yeah Michael
It's a series xo, 0.5mH inductor + 3.4uF cap + 10ohms resistor (in series with the tweeter) with the same layout as the other one I sent you.
On another centre Vb=8.3 litres with the same drivers has 0.47mH + 3.3uF + 9ohms.
Old 14th December 2003, 10:55 PM   #9
Default rabbitz......
hey rabbits can you tell me what slopes are those on the XO and also at what frequency have you got them crossed?
Old 15th December 2003, 05:00 AM   #10
sreten:
where can I purchase a crossover specifically designed for that aluminum cone midbass? If I can't purchase it, where can I get instrucion on how to build it? Thanks
What are some decent drivers for a small/mid size center channel speaker (1 mid,1 tw)Hide this!Advertise here!
Center channel speaker LEESTER Car Audio 0 9th April 2007 08:18 PM
center channel speaker design legendaryfrog Multi-Way 23 29th October 2006 08:07 PM
Quad Tang-Band drivers for center channel DcibeL Multi-Way 4 19th November 2004 09:15 PM
Drivers for small center channel? Sawzall Multi-Way 4 16th June 2004 12:25 AM
Foam blocks between 2 Tang Band 3" full range on a small center channel The Paulinator Multi-Way 5 27th March 2003 05:04 AM
