Old 11th December 2003, 10:16 PM   #1
Keith D is offline Keith D  United States
Talking what happens when you hook up xover wrong
Speaks for itself. It was 600 before I got the camera.
What happened is I had the tweeter network wired backwards. That is, I had accidently wired the tweeter to the input instead of the output.
They sounded nice too until the first two resistors started sizzling the glue, the drivers survived too, and I was definitly pushing more than 60 watts through them, with a lot of bass too, the woofers were snapping really hard. I just modeled the mistake in speaker workshop and it looks like I had a 1500 xover going, no wonder it was so good at low volumes!
Just a warning to all of you, hook your xovers up right, or else!
proper xover schematics and graphs from Curt C
Old 13th December 2003, 12:33 AM   #2
no comment..... lol
Old 13th December 2003, 01:21 AM   #3
diyAudio Senior Member
fdegrove's Avatar
What happened?
Nothing should happen other than an out of phase/polarity hook-up, bo damge should be done.
Frank
Old 13th December 2003, 04:29 AM   #4
No, I wired it completely backwards. I plugged it into Speaker Workshop and the overall impedence was roughly 2 ohms, so my NAD amp really does have some balls! Basically the resistors that were supposed to be after the inducor and capacitors were instead before, so they were soaking up lots of power.
I'm debating whether I should make another PE order to replace them, it all sounds ok now that it's wired right, but I have a feeling the heat damaged them.
Wrong Voltage / current on BoZ... or Wrong Measuring ? gionag Pass Labs 8 14th May 2008 11:24 AM
Did I hook this up right? HolyGhostFire20 Parts 7 6th August 2005 09:15 PM
What's wrong here? Xover calculators... jjdche Multi-Way 3 4th June 2004 07:31 PM
Hook-up Wire? mwh-eng Tubes / Valves 6 4th March 2004 07:30 AM
hook up wiring sriegel Pass Labs 2 13th January 2002 04:41 PM
Page generated in 0.07208 seconds (73.78% PHP - 26.22% MySQL) with 11 queries
