Old 20th August 2004, 11:41 PM   #41
GM is offline GM  United States
GM's Avatar
Originally posted by Nelson Pass
My point would be that 45 degree corner reflectors might
only make a subtle difference, but they do so on several
fronts. They do stiffen the enclosure, they do allow a more
accurate taper with a folded pipe, and they do provide some
reflective/diffusive effects which reduce unwant internal
resonance. Having tried it both ways, I find that I prefer
the sound, what else can I say?
Hmm, as I noted, my experience mirrors BB's measurements/conclusions, so unless the cab is designed to use reflectors, simple corner glue blocks made from scraps work just fine for stiffening up the corners and the requisite stuffing sufficiently attenuates reflections back through the driver, so I'm curious what's causing the differences you're hearing, unless you're designing around reflectors, then comparing with/without them Vs a cab that's properly folded.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 21st August 2004, 12:01 AM   #42
GM's Avatar
Default Re: Hi GM
Could you explain to me how you can tell that the cabinet is ringing from the plot I posted. I punched in a number of different stuffing densities, up to 2 lbs/ft and it only nominally changed the curve. Perhaps I'm missing something. [/B]
I meant the alignment would 'ring' excessiviely due to the huge Fb peaking. This is normally caused by way too much Vb and/or too high a tuning, and no amount of polyfil stuffing that MJK's worksheets will factor in will attenuate it enough and it doesn't allow us to choose fiberglass, wool, etc., so based on your listening review I'm doubtful the plot is accurate, but we need to look at the design to see what the actual plot should be and figure out what needs to be done to the design to further improve its in-room response.
GM
Old 21st August 2004, 08:49 PM   #43
teodorom's Avatar
Default Folded and unstuffed line measurements
It appears that some of you built some TL (or ML-TQWT) having a folded line.
My problem is that in the scientific literature (Webster Horn Equation eventually applied to musical instruments, like trumpets and so on) it is often quoted that folding has effects on resonances, the fundamental and so on.
Translated in some other language it appears that Leff is dependent upon the frequency.
This can be disturbing in TL's and ML-TQWT's where the position of the driver (and the port) is critical.
Unfortunately until now I' haven't found (on the Net) anything quantitative (and predictive).
In order to understand the problem I need to correlate the physical design with the measurements (with the line unstuffed).
Any contribution ?
Teodoro
Old 22nd August 2004, 01:09 AM   #44
The one and only
Nelson Pass's Avatar
Originally posted by GM
Hmm, as I noted, my experience mirrors BB's measurements/conclusions, so unless the cab is designed to use reflectors, simple corner glue blocks made from scraps work just fine for stiffening up the corners and the requisite stuffing sufficiently attenuates reflections back through the driver, so I'm curious what's causing the differences you're hearing, unless you're designing around reflectors, then comparing with/without them Vs a cab that's properly folded.GM
Since I happen to be building up some in the next two weeks,
I'll see about making a measurement. Of course, if you are
stuffing the tube sufficiently, that's another item, but I notice
that a lot of the TQW crowd doesn't seem to be stuffing at the
fold.
Old 23rd August 2004, 04:42 AM   #45
The one and only
This would be a repeat of the same picture posted elsewhere
to what amounts to the same question. It is Beranek's plot
of attentuation vs frequency for a bent duct having a 1 foot
diameter (or its equivalent). My point being that a 45 degree
strike plate would show some sort of difference.
Old 24th August 2004, 01:43 AM   #46
Setting questions of effect on line length etc. aside, I've always figured that it was nearly mandatory in order to break up standing waves in the section of pipe in question. I once did a four-fold transmission line and regarded the flat, parallel ends of each section of the line as resonances waiting to happen. Given that there were four pairs of opposing surfaces, all the same distance apart, any standing waves would have been reinforced beyond tolerance. Putting diagonals in each corner was an easy solution.
Though I know the math is different, I am just as suspicious of sudden changes in tube cross section in transmission lines as I would be in horns. You're setting up a non-linearity in the impedance. Putting a diagonal plate in the corner helps ease the transition.
Grey
Sine wave - Square & Triangle wave generator using Transistors / OP-Amps lineup Solid State 20 9th October 2006 12:15 AM
tapered pipes vs others theChris Multi-Way 7 8th July 2003 05:59 AM
Microphone turns triangle wave into square wave? Circlotron Analogue Source 18 25th January 2003 06:44 AM
Copyright ©1999-2013 diyAudio
