Flush Mounting (a la Epos) - To What Effect?
Old 7th August 2013, 11:45 PM   #1
schmalex is offline schmalex
Default Flush Mounting (a la Epos) - To What Effect?
I really like the clean look of Epos speakers, not to mention the sound. I'm designing a pair of speakers to build later this fall. I'm curious - they mount their drivers behind a false baffle. What effect does this have, if any? The tweeter is flush-mounted, more or less. But the woofer sits behind a big radius edge. One thought - it would set the tweeter and woofer further out of time alignment. I have heard these particular speakers, and was quite impressed. So I'm not trying to be critical of the design, but rather understand if I can apply the same treatment in my design.
From Epos literature - "The cosmetic harks back to the early 80s roots of the Epos brand, but the distinctive removable front carries no screws or grille fixings to clutter its elegant lines. Instead, the front baffle could be seen to be a cosmetic trick to hide the drive units which are mounted conveniently on a sub panel that contains all the screws and fixings, thereby leaving the front clear."
Old 8th August 2013, 03:17 AM   #2
Jay1111 is offline Jay1111  United States
It's just rear mounted with a chamfer. It's a pretty common thing to do with woofers featuring ugly or irregular shaped frames.
Lots of examples and discussion in this thread
Drawbacks to rear mounting drivers?
Old 8th August 2013, 04:35 AM   #3
Greebster is offline Greebster  United States
Greebster's Avatar
Some just shouldn't be seen.
I'd be more concerned with those sharp enclosure edges. ≥ " roundovers for me. Then flush mount.
Flush Mounting (a la Epos) - To What Effect?Hide this!Advertise here!
Flush Mounting Drivers (a la Epos) - What Effect schmalex Full Range 0 7th August 2013 11:31 PM
router bits for flush mounting eisenhower Multi-Way 12 27th December 2006 01:24 PM
Importance of flush mounting drivers RyanC Multi-Way 16 27th May 2004 09:10 PM
flush mounting subwoofers? Jhovis Subwoofers 1 30th December 2003 03:59 AM
substitute for flush mounting Chris_W Multi-Way 8 9th May 2002 02:25 AM
