Filter Suggestions for SEAS 27TFFNC/G
The Madisound Speaker Store
I'm thinking of putting a pair of these in my car; Zaph says they can be XO'd down to 2k; they'll be paired to 5" woofers that go up to 4k (old Peerless that I have no info on - running filterless).
Wondering if anybody has any suggestions on a filter design? Or, if you know the design on the Zaph ZA5 Autosound kit (uses the aluminum dome version) that would probably be fine too.
Thanks!
Here's Zaph's crossover
And the driver roll off
You'll have to play with the value of R2 to adjust the treble level. A higher value resistor will give you less treble.
