Hi
The Vifa website doesn't show any info on the M22 WR-09-08 8" paper cone driver. It's still available in Australia (with limited specs). To those that have used it, could I have your opinion of it, please? It seems like a good driver for a smallish box (<30-40L), with good power handling and good xmax (6.5mm?). Although, it's a bit more expensive than a lot of other 8" drivers in it's (apparent) class. Thanks in advance. Mos |
#2 |
I am also considering using this driver. I found specs for it at ApexJr but they don't closely match the specs I found elsewhere. Therefore I do not know whether I wish to use this driver or not. Also I wish to use a PR design but I don't know anything about them, and I just read some bad stuff about PR designs.
Pete |
#3 |
Mos,
I have looked at this driver and wonder if it is really worth the extra over the 8" polycone. The only advantage I can see is that it looks better!!! The M18 does look better than the P17 and has been compared to the venerable SS 18W at less than half the price. I don't know if the same can be said for the 8" version, but if so then it might be worth considering. I suppose this is where the numbers don't tell the story. The LDSG has some comments, and says many consider the poly to be Vifas best 8" driver. LDSG "P21WO-20-08, an 8" (21 cm.) PP cone woofer. There seems to be a consensus that his is the best of Vifa's 8" woofers. It has good, well-behaved extension on both sides of its passband." Seas has a similar driver, I think it is a bit cheaper, worth checking out. regards, Paul
AUDIO BLOG | Bass integration guide My work: www.redspade.com.au web design studio |
#4 |
This is from Vifa Spec sheet.
Nominal Impedance = 6 ohms Voice Coil Resistance = 4.3 ohms Nominal Power (IEC268-5) = 150W Music Power (DIN45500) = 200W Operating Power = 7.5W Sensitivity (1W,1m) = 88dB Frequency Range = 30-1000 Hz Free Air Resonance = 30 Hz Voice Coil Diameter = 50mm Voice Coil Height = 21mm Air Gap Height = 8mm Voice Coil Inductance = 1.1 mH Effective Cone Area = 224cm sq Moving Mass (incl air) = 36g Magnet Weight (37.4oz)=1062g Force Factor, B X L = 8.8Txm Vas = 55 ltr Qms = 2.73 Qes = 0.38 Qts = 0.33 Regards
Michael Chua |
#5 |
hi, mcp, i was just wandering, could you find any info about vifa m22wo-01 8'' 4 ohms model?
#6 |
#7 |
Oh... if there was any info at the DST's site I wouldn't ask here...
Google doesn't know anything. |
#8 |
You're right - it's not on DST's website or easily found via a google search, but here is a speaker which uses an M22 driver, so you might ask steve
You might submit a request here ... Another alternative is to look at programs like WinISD and look at the parameters of very similar drivers. I found: M22WR-90 M22WR-09-06 M22WR-19-04 M22WR-29
#9 |
Thanks a lot!
I think M22WR-19-04 will do |
| Greetings and request for info on Cat SL1 preamp | somi electronic | Parts | 1 | 25th March 2011 09:01 PM |
| Naim Nap 110 info request | mcolliva | Solid State | 1 | 8th April 2007 10:44 PM |
| KRELL KSA50 power supply - kind request of info. | beppe61 | Solid State | 32 | 5th November 2005 03:44 PM |
| Info request on TDA2612 | JohanH | Chip Amps | 0 | 24th February 2005 05:28 PM |
| Page generated in 0.10081 seconds (80.01% PHP - 19.99% MySQL) with 10 queries |
