I've created a website that explains loudspeaker theory with simplified language and illustrations. The address is:
www.cyberus.ca/~ec091357/HomePage.shtml |
#2 |
I am most definitely a novice. I have read many articles on crossover networks, and am uterly confused.
When I look at these diagrams (such as the one at the end of the link above), I don't understand the "bridging" used between the positive and negative leads. I looks to me like the signal would pass straight through, and the "bridge" with the inductor and capacitor would have no effect. Maybe someone can let me know what I am missing. Sorry if I am using the wrong terminology. |
#3 |
A very attractive web site with excellent pictures. Well done.
#4 |
Very nice site with good basic stuff.
If your open to suggestions I think with such good quality diagrams using a typical rather than simplified magnet structure with the magnet ring and pole pieces would aid understanding. |
#5 |
SB :
The diagram may be confusing you with its central earth, the wiring is in paralell, not bridged, top and bottom are poth positive. |
#6 |
Hello SB
Thank-you for your reply. The diagram may be confusing as the woofer and tweeter are electrically connected to the amplifier in opposition. The positive terminal on the woofer is connected to the negative (or earth) terminal of the amplifier, and the positive terminal of the tweeter is connected to the positive terminal of the amplifier. This wiring corrects for the phase problems between the woofer and tweeter that occur around the crossover frequency. A noticable dropout will be present in the upper midrange if the tweeter and woofer are not connected in this way. Hope this helps. Stephen |
#7 |
Thank-you for your encouragement, 7V.
Stephen |
#8 |
Thank-you for your reply, "sreten". With regards to the oversimplified magnet structure, I wrote a disclaiming note in the introduction, instead of making the extra effort with the diagram. Sheer laziness.
Stephen |
#9 |
Thank you for your help. I have a mental block somewhere that won't let me see what the wiring should look like in real life. I will keep reading!
#10 |
| primer for fiberglass | pjoseph | Subwoofers | 5 | 4th August 2009 12:03 AM |
| Fi Primer 807 | Klimon | Tubes / Valves | 2 | 13th November 2007 07:58 AM |
| A cooling Primer? | Pbassred | Solid State | 9 | 29th March 2007 06:00 PM |
| Loudspeaker design in general *novice* | bob_bsme | Multi-Way | 6 | 20th November 2006 04:34 PM |
| Help me pick a good primer for my box | ma_tt316 | Subwoofers | 5 | 4th December 2005 01:57 PM |
| Page generated in 0.09078 seconds (79.87% PHP - 20.13% MySQL) with 10 queries |
