mid-woofer replace suggestion for MS Konsens II
Old 26th July 2013, 10:44 AM   #1
Polios is offline Polios  Greece
Default mid-woofer replace suggestion for MS Konsens II
Hello
please if you can help me I have built the following kit MS Konsens II by Intertechnik
ftp://radiozona.myftp.org/Radiotehni...nsens%20II.htm
MS KONSENS II Gehuse
MS KONSENS II Frequenzgang
MS KONSENS II Weiche
my daughter broke down the mid-woofer SEAS Wt 171 and will have to replace the speaker that is no longer manufactured contacted the intertechnik and the Seas for what speaker they suggest but no answer. I do not know many of these things I just like the construction.
if you kindly suggest me some speaker preferably with the same diameter as not to spoil the box regardless of the brand that fits the characteristics of my speakers
if necessary I replace both and the good from the other speaker.
Thank you very much for your time
Pavlos
Old 26th July 2013, 05:25 PM   #2
Inductor is offline Inductor  Portugal
Inductor's Avatar
REPAIR/RECONE: Before we go for a replacement check for a repair of that driver (or pair) or recone with a professional repair shop. You have the second item (pair) what is useful for any detailed measurement needed (before/after).
REPLACEMENT: First would be important to identify this driver to match it with it's complete specs (electro-acoustic parameters).
Also at this time check (post in forum) for the size, internal/external diameter, or if matches the size of a standard reference driver.
Now, for some links. Identify your driver first to match correct spec-sheet or most similar. Here some vintage list of SEAS drivers.
SEAS VINTAGE PRESTIGE WOOFERS
Is your driver in anyway similar to this one? What is the reference number for it (H####)?
SEAS H0630 CC17RC (17 cm woofer) we can read this reference in the bottom: W17-101. Is it a paper cone?! After identifying the driver is less difficult to go for a similar/equivalent.
Another interesting link on similar driver. Seas WT 171 H634 (XP)
After all, without the proper driver, it's a very difficult job and time consuming, almost impossible for a newbie, not running some simulations and reverse engineering of a complete speaker system.
Old 27th July 2013, 06:41 AM   #3
thank you very much for your answer i post some photos
Old 27th July 2013, 07:15 AM   #4
the speaker was make a noise chrrrrrr chrrrr the cone looks like it has move at the side and touch the metal my mistake was that i heat it with a hairdryer but i uglify it it still works and sounds better less chrrrrr and at high volume but i need to replace it
thanks Pavlos
Old 27th July 2013, 07:22 AM   #5
one more
Old 27th July 2013, 07:38 AM   #6
still have the kit instructions
Old 27th July 2013, 08:49 PM   #7
Inductor's Avatar
Default Seas H 643-08 T17RCYP-H
Grateful for your concern and nice postings of your document set but what we need is the full driver specs.
Something like the specs linked below.
You should know that the material of the cone is a "PP/TPX based cone" (look here) that you find in some of the old and new Seas drivers but the physical exterior dimensions are now "18" in the modern drivers and not "17" (170.4mm).
The Seas vintage drives might not be commercialized anymore but you can try always contacting the source at SEAS.
I made a list of the vintage Seas drivers that would be valid equivalent drivers both in T/S specs and physical dimensions. Notice that they are discontinued. Using a different driver requires a new crossover/testing/simulation of a new speaker and components+drivers. Some newbies don't understand that, they are the "dummies"...
Now to start the list the most close in spec driver that I found follow next by the other similar references to your driver.
Seas H0627 P17RC/TV
H0352 P17RCY
H0548 P17RCY/P
H0571 CB17RCY/P
Note: If you know of someone speaking Russian try this link. Always run payments with controlled bank accounts (bank transfer operation), don't give away your credit card number.
Post results. Have fun.
Old 27th July 2013, 09:11 PM   #8
Inductor's Avatar
The Seas H571 you may find it here.
SEAS Prestige Midwoofer W17PPI phaseplug - 135,47EUR in Italy
Seas - Audiokit E-commerce - Vendita componenti elettronici
Link for the above W17PPI/Seas Woofer-Midrange loudspeaker W 17 PPI H571
File Type: gif W17PPI Seas Woofer-Midrange loudspeaker W 17 PPI H571.gif (150.4 KB, 28 views)
Old 28th July 2013, 03:57 PM   #9
Thank you so much appreciate your help and your quick response you are great
I think the one for the best solution is Intertechnik the company that design this kit they can tell me what fit there. i have already send them email with all above details and ask them if they can help me with money of course I hope they have after sales service.
if not i will need your here.
thank you so much for your time
Pavlos
Old 28th July 2013, 04:21 PM   #10
Inductor's Avatar
Pavlos,
You are welcome.
mid-woofer replace suggestion for MS Konsens IIHide this!Advertise here!
WANTED: 6-7 inch pro mid/woofer or some small box woofer Jimmy154 Swap Meet 10 18th August 2012 12:01 PM
Need a opamp suggestion to replace a NJM4558D gaetan8888 Solid State 59 5th April 2012 07:26 AM
WTB: 6.5" woofer to replace broken woofer in cheap band pass subwoofer Jimmy154 Swap Meet 2 5th October 2010 02:00 PM
Need some Revelator mid-bass system design suggestion F.L. Multi-Way 1 25th April 2003 08:06 AM
