Homemade Speaker
Homemade Speaker
Old 23rd July 2013, 02:45 PM   #1
Xiliavus is offline Xiliavus  Australia
Default Homemade Speaker
Hi recently i built a homemade speaker system but it is constantly emitting a buzzing sound. I have simply two speakers connected to an amplifier and a 12V power source. I have also noticed that if im physically touching the negative wire of the speakers then the buzzing stops. This is annoying me as anything else i connect it to still causes buzzing its only me that stops it. Does anyone have any ideas how to fix this it would be greatly appreciated?
Old 23rd July 2013, 08:21 PM   #2
Greebster is offline Greebster  United States
Greebster's Avatar
A grounding issue for sure. Possibly a bad cable and use a star ground scheme to a good solid earth ground (copper water pipe or ground rod)
Old 23rd July 2013, 11:44 PM   #3
BlueWizard is offline BlueWizard  United States
Buzz or Hum?
Buzz implies a mechanical sound as it something phyisically loose and rattling.
Hum implies an electrical sound, as in 60hz line hum.
Which do you mean?
If this is an electrical sound, then yes, you have some kind of ground issue. It could be a ground loop on the AC side. Or it could be a bad ground wire on the music side.
But, what it is, is difficult to determine without a few more details.
You claim the system runs off 12v, is that a 12v power supply or a 12v battery? And if a 12v power supply, what kind of power supply?
You say it stops if you touch the negative wire, but do you mean anywhere on the wire, or do you mean you touch the Bare Exposed Metal part of the wire? Or do you actually mean the Negative Speaker Terminal?
These all tell us different things, so we need precise details not generalizations.
Steve/bluewizard
Old 24th July 2013, 05:46 AM   #4
Default @Bluewizard
Thanks for the help so far
anyway...
The sound seems to be both a hum and buzz. The hum stops when i touch the actual wire to answer your other question though there is a slight buzz. I'm not to concerned with the buzz as it is a very small sound but the hum is incredibly annoying (although if anyone has an idea for the buzz would be great to).
I've tried running it off an AC household power point with an adapter a 12V and also my power source generator, each giving the same result.
One thing i want to add is atm it is connected with alligator clips. Was going to properly solder some audio wire onto it later once i figured everything out but could this be a cause of the problem.
Old 24th July 2013, 01:27 PM   #5
Greebster's Avatar
Having done exactly as you have, experienced this hum induced buzz. Solid ground connections are a must. Still would suggest checking the cables to see if there is a weak link.
BW, you've never experienced hum induced buzz? Normally I've found the problem is two fold. Poor grounding and a bad or inadequate ground in a signal line or an open ended unterminated signal input is all it takes to produce this.
Old 25th July 2013, 05:28 AM   #6
In terms of making a 'ground' connection could i just put a bit of copper pipe or something with high/low resistance in my speaker. I intend it to be portable so i dont want to be putting a giant piece of anything in there to make it work. Is there anything that works particulary well.
Old 25th July 2013, 06:37 AM   #7
Saturnus is offline Saturnus  Denmark
Saturnus's Avatar
Please provide a simple wiring diagram. That'll make it much easier to find the source of your ground loop problem. And please state what exact components you're using.
Old 25th July 2013, 11:01 AM   #8
AllenB is offline AllenB  Australia
Maybe this is the result of oscillation considering the alligator clips.
Old 25th July 2013, 12:24 PM   #9
ODougbo is offline ODougbo  United States
I keep a 12 volt battery around; lawn tractor, etc. to check things like this.
Homemade SpeakerHide this!Advertise here!
Building a homemade speaker Swankz Construction Tips 3 22nd July 2013 10:04 PM
homemade resistors Lostcause Parts 7 7th June 2007 08:34 PM
homemade faceplates PRNDL Tubes / Valves 6 10th March 2007 05:00 PM
Homemade magnets and homemade magnetizer jacquesl The Lounge 0 19th February 2007 07:32 AM
Homemade heatsinks Sch3mat1c Swap Meet 5 8th February 2005 02:46 PM
