Is it ok to have multiple tweeters in each channel? - Page 2 - diyAudio
Old 22nd July 2013, 06:05 PM   #11
Zertman is offline Zertman  United States
Originally Posted by nannoo View Post
doubt you'd fry the resistors. Have you measured the woofers at all?
particularly for impedance i mean
Did you mean "fry the tweeters"? I haven't measured the woofers but they are marked 4 ohm on their magnets.
Old 22nd July 2013, 06:06 PM   #12
Greebster's Avatar
Now that we've covered how to electrically integrate them how about some advise with physical configuration do's and don'ts.
Old 22nd July 2013, 06:42 PM   #13
I took a picture of how my front speakers are setup:
I know the left and right speakers are too close to the center one but I don't have enough room to move them further apart.
Old 22nd July 2013, 06:58 PM   #14
How are you guy's getting 6db? If the 4 ohm resistor is removed the amp will see half the impedance or a doubling of the wattage which is 3db. Am I missing something?
Also, IIRC, the added resistor changed the cut off frequency of the tweeter effectively moving it up an octave.
Old 22nd July 2013, 07:19 PM   #15
So I removed the inductors and resistors and it does sound better. I kinda scared of cranking it, though. How can I tell if I am frying the tweeters?
Old 23rd July 2013, 03:15 AM   #16
The Pyramid tweeters have ferro fluid which, among other things, helps to transfer heat away from the voice coil. IME, such tweeters are hard to fry. The best thing to remember is that audible distortion is what tends to take out modern tweeters. So turn it down if you here the tweeter distorting.
Old 23rd July 2013, 04:21 AM   #17
Voltage.
The resistor was on the amp side of the crossover, so it should not have changed to response much.
Old 23rd July 2013, 08:12 PM   #18
Greebster's Avatar
If you can see it move it's too low and no amount of ferrofluid will save you. Additionally crossing too low causes a massive amount of distortion and may exceed the one octave above resonance rule (to keep it clean).
Old 24th July 2013, 12:22 AM   #19
Originally Posted by dumptruck View Post
Voltage.
Thanks for the correction on the resistor.
However I still disgaree on the 6db. FWIU, You are refering to electronics in which you are dealing only in the voltage domain in which doubling the voltage results in 6db increase. In speakers we are in the power domain (current comes into play) and have doubled the wattage which is a 3db increase.
Old 24th July 2013, 12:37 AM   #20
The resistor is dissipating power, dropping the voltage. What you have done to the power that is actually seen by the driver? You're correctly estimating the difference in power being supplied to the whole circuit.
Using multiple tweeters in parallel gnalbant Multi-Way 12 2nd February 2016 08:30 AM
multiple output transformers per channel cyclecamper Tubes / Valves 23 29th December 2014 04:09 AM
Multiple speakers on a channel sharpstick Multi-Way 1 14th February 2013 02:49 PM
what happens when you use multiple tweeters? tuckers Multi-Way 1 14th November 2009 10:46 PM
Multiple drivers in same enclosure & resistors for attenuating tweeters bm_mode Multi-Way 4 14th October 2001 03:21 PM
Copyright 1999-2017 diyAudio
