Dynaudio Audience 52 problem! - diyAudio
Old 20th July 2013, 01:01 PM   #1
froderic's Avatar
Default Dynaudio Audience 52 problem!
Dynaudio Audience 52 problem tweeter
Hi, everybody!
There was such problem, whisky drops on tweeter got, wiped a napkin and removed the put layer! High frequencies became much less. what it is possible to make how to restore, than to cover?
With big respect of froderic
Old 20th July 2013, 01:09 PM   #2
Mooly's Avatar
Moved to multi way forum
Installing and using LTspice IV. From beginner to advanced.
Old 20th July 2013, 09:23 PM   #3
Contact Dynaudio and see if they have a replacement tweeter.
Likely these are Silk Dome tweeter that have had some type of coating added to the silk to keep them stiffer and to allow them to push more air. Alcohol being a solvent, probably dissolved the coating.
I can think of ways to restore the coating, but not while the tweeter is assembled, and even if you could manage to coat the tweeter, there is no guarantee it would sound like the other one.
Best to try and get a replacement, or short of that, see if Dynaudio has a pair of equivalent that you could substitute for the existing tweeter.
Alternately, simply find two similar tweeters with a similar form factor, and substitute them. Though from the photos I've found, the tweeter frame has a small section cut out so it conforms to the arc of the woofer. That makes it difficult to find a generic replacement.
Also, if people are spilling whiskey on your tweeters, you need a better class of friends.
Steve/bluewizard
Old 21st July 2013, 09:46 AM   #4
froderic's Avatar
Steve/bluewizard I thank for a response, everything is very correct!
Maybe who will prompt number tweeter Dynaudio Audience 52, I will look at EBAY or to order in Dynaudio of the dealer.
And now there is a wish to listen to music, and all the same to throw out tweeter, so prompt than to impregnate it? - it can turn out to restore not much, before purchase new, very interestingly!
Your froderic
Old 11th October 2013, 07:28 AM   #5
froderic's Avatar
Your froderic
Prompt please number tweeter Dynaudio Audience 52
Old 11th October 2013, 09:14 PM   #6
The tweeter is an dynaudio d28/2 (not the d260).
http://www.htforum.nl/yabbse/index.php?topic=80902.0 (dutch)
Old 14th October 2013, 01:16 PM   #7
froderic's Avatar
Many thanks friends!
Yours faithfully
Old 14th October 2013, 02:08 PM   #8
froderic's Avatar
And where to make the order?
Old 14th October 2013, 06:06 PM   #9
Eldam is offline Eldam  France
Second hand like the D260 (but have to set up the crossover) or Dynaudio itself, because you can't buy new dynaudio drivers nowadays. Ask to Dynaudio.
Maybe less expensive to buy a pair of new one in second hand : go to the 52SE for 500 euros... maybe the same prices than 2 tweeters from Dynaudio factory !
dynaudio audience 52 for sale ValcMilton Swap Meet 2 5th October 2011 02:18 PM
My reverse engineering of a Dynaudio Audience 52 mr_push_pull Multi-Way 11 31st December 2010 12:15 PM
Modding Dynaudio Audience 52 jsa_ind Multi-Way 0 5th December 2009 04:00 AM
filter of dynaudio audience 52 max29 Multi-Way 6 24th September 2006 11:25 AM
Dynaudio Audience 50mk2 hifive Multi-Way 2 8th April 2006 03:52 PM
Copyright 1999-2017 diyAudio
