SQ Oriented Boombox:  Design Help Needed
Old 24th July 2013, 09:05 AM   #21
Saturnus is offline Saturnus  Denmark
Saturnus's Avatar
I'm not sure I get the point here. Every time you've asked this question you've been advised by myself or others to do exactly what a Boominator does. Not wanting to flog a dead horse here but since you lack the ability, the know-how, and basic understanding of the requirements that goes into designing a speaker specifically for outdoors use, I don't get why you don't just build a Boominator or half-Boominator as it's specifically engineered to fulfill your requirements.
Old 24th July 2013, 05:16 PM   #22
Greebster is offline Greebster  United States
Greebster's Avatar
Warning on DC/AC inverters. All of the cheaper ones do not produce a sinewave output. Instead they have what could be called a 2 bit square wave. This produces very high electrical noise that will be heard unless highly filtered first. This added filtering will end up reducing the output level to less than optimal (say 100v VS 120). Also don't forget to add the conversion losses to the total power used. Typically no better than 60-70% @ load, if not fully loaded this decreases. Have installed several high power inverters for emergency response vehicles and this is one of the requirements. Higher efficiency as a bonus, typically in the 90% range @ load. These inverters are expensive.
Old 24th July 2013, 08:20 PM   #23
Saturnus's Avatar
Add to it that an amp is far from a constant load, and typically average 10-15% of full load where efficiency is much lower still. It's all together a horrible solution.
SQ Oriented Boombox:  Design Help NeededHide this!Advertise here!
ORIENTED or Not ORIENTED cores for OPT ja2dhc Tubes / Valves 14 5th July 2008 01:31 PM
Grain oriented silicon steel core data needed eppidei Tubes / Valves 0 14th September 2007 03:08 AM
First time build help needed budget oriented sbrunkow Multi-Way 1 24th October 2006 06:23 PM
new design idea in the quest of SQ Nemophyle Multi-Way 26 17th January 2006 06:49 PM
help me refine this SQ design...please Audiophilenoob Multi-Way 8 13th June 2005 03:24 PM
Copyright ©1999-2017 diyAudio
