Old 20th July 2013, 02:58 AM   #1
Default Jaycar exciter
Broke out my Arta Jig for the first time in a while, playing with this gizmo:70mm Flat Panel "exciter" Speaker - Jaycar Electronics
plan is to use it in a cigar box guitar, thought the impedance plot might be of interest (the suspension on this this is very heavy, I suspect the Fs will drop quite a bit after serious break in)
Q&D TSPs: Fs = 212.27 Hz
Re = 7.60 ohms[dc]
Le = 116.97 uH
Qt = 2.99
Qes = 3.69
Qms = 15.91
Vas = 0.09 liters
Sd= 38.48 cm^2
Lp(2.83V/1m) = 75.61 dB
Impedance varies with frequency, use impedance plots of your drivers and make crossover calculations using the actual impedance of the driver at the crossover frequency
Cartridge Exciter exurbia Analogue Source 8 12th April 2009 09:58 PM
Bass Exciter build dublin78 Subwoofers 1 25th September 2007 01:10 PM
exciter... alecwek Parts 2 10th August 2004 01:45 PM
Aural exciter modification noground Parts 0 1st April 2004 06:32 PM
Tube exciter tiroth Tubes / Valves 9 22nd October 2003 11:28 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
