3-way Woofer Selection Help
Old 20th July 2013, 12:21 AM   #1
ODougbo is offline ODougbo  United States
Default 3-way Woofer Selection Help
Building a three way seems to make sense, since have tweeters and mid woofers from other abandoned projects.
Two DIY favorites: Peerless 83870 and XT25 - as shown in pic
The Madisound Speaker Store
I don't have woofers for a 3-way, looking for a 10" or good quality 8", maybe double 6.5"s; open for suggestions.
Action films can be brutal - however I typically lean toward vent boxes as long as bottoming-out is not a problem. I don't play speakers "loud", but use black box amps, 150w-200w per channel.
Approximate size: Three cubic feet is about my limit, or just too hard to move around, etc.
Any help is greatly appreciated!
Old 20th July 2013, 12:41 AM   #2
Face is offline Face  United States
Face's Avatar
Seas L26 will dig deep in a 2.5 to 3.0cf cabinet.
"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Old 20th July 2013, 08:09 AM   #3
Default MMTMM
Thanks Face, that is a heck of a woofer.
Thinking my best bet is a MMTMM, e.g. this is salvage from MS's "HDS kit", with a 8liter chamber built-into the center of a box, they could go down to 100hz (if needed). [not the large cap, that was buried in drawer]
Old 21st July 2013, 12:48 AM   #4
cT equals piD is offline cT equals piD  United States
If you are willing to go with a 12" woofer, I would suggest MCM Audio Select 55-1465. Each of my primary pair of stereo speakers that I'm listening to music with has this woofer in a closed-box of interior volume 2.8 cu. ft. I just love the sound.
If 2.8 cu. ft. is too large, it can be given a vented alignment in a 2.14 cu. ft. enclosure following what Marshall Leach has published.
Both the sealed and vented alignments end up with about the same f3 = 40 Hz.
Old 21st July 2013, 03:09 AM   #5
_henry_ is offline _henry_  Australia
dual anarchy, currently the best 7" woofer on sale $50.
vented 29L, can go down to 30hz in room. max spl at 200w with 112db.
small box, healthy xmax 12mm, alum cone.
best 7" ever!
Old 21st July 2013, 08:42 AM   #6
Resurrection of the Anarchy woofer? Where do you buy them?
Can't beat the MCM driver prices, 1/2 or less than the other suppliers.
Old 21st July 2013, 08:54 AM   #7
Jay1111 is offline Jay1111  United States
The Anarchy would actually be a pretty cool choice for a 2.5 way mmtmm. Sensitivity is still pretty low though. You can get down below 30hz in a 3 ft3 box with four of them, and handle a full 500 watts without excursion issues.
DIYCable.com : Intro Home Exodus Anarchy
Old 21st July 2013, 09:12 AM   #8
That sounds like a plan
Would the Dayton tweeter work with this, or just too much to ask?
Old 21st July 2013, 12:15 PM   #9
Looks like the Exodus out performs a competitor in a box half the size.
With a 54L box 2- ports are in the 3/4" x 9" x 9" range.
Old 21st July 2013, 01:49 PM   #10
where to buy anarchy? diycable.com, kevin still listed it on his site.
3-way Woofer Selection HelpHide this!Advertise here!
2-way omni woofer selection puppet Multi-Way 9 3rd February 2012 03:30 PM
Chip Selection for woofer? rgrayton Chip Amps 0 15th April 2005 02:49 PM
Woofer and configuration selection Daniel_AVR Multi-Way 0 7th May 2004 03:26 AM
Woofer selection jainbaby Multi-Way 6 3rd January 2003 02:28 PM
bandpass enclosure woofer selection Opie Multi-Way 1 21st September 2002 07:57 PM
Copyright ©1999-2017 diyAudio
