Old 8th December 2003, 08:50 PM   #1
pixaren is offline pixaren  Sweden
Default Crossover for 2.5-way speakers...
I wnat to make a crossover for my 2.5-wayspeakers that i should build.
The problem is that i'm not really sure if my schematic i made is corect!
http://w1.454.telia.com/~u45410036/Delningsfilter.jpg
(PICTURE OF MY CROSSOVER)
Tweeter: 6 Ohm
Bas 1: 8 Ohm
Bas 2: 8 Ohm
I want to cut the freq. as follow:
Bas 1: 0-800Hz
Bas 2: 0-2500Hz
Tweeter: 2500-and up
'The xo-filter i made is a 2nd Linkwitz-riley
/pixaren
Old 8th December 2003, 09:46 PM   #2
delwon is offline delwon  United States
Pixaren,
Your schematic looks to be something that will work. I've built two pair of 2.5 ways and I did my xover a bit differently. Based on your numbers, I'm guessing that your two bass units are 6.5" drivers. I don't know what drivers you're using, but when I built my 2.5 way using two Audax 6.5" units, I ended up with a 1.2mH coil in front of woofer 1 and a 3mH coil between woofer 1 and woofer 2. In other words, the two woofers were wired in parallel with the 3mH coil between the main woofer and the .5 woofer. It works well for me.
Based on your chosen cross point for the main woofer, you'd use something smaller than a 1.2mH coil.
Old 8th December 2003, 09:52 PM   #3
It doesn't look right to me, you have 4 ohms in series with everything.
You cannot model the drivers as simple resistances.
You should use a 1st order filter on the '0.5' driver for baffle step compensation.
/sreten.
Old 9th December 2003, 05:39 AM   #4
I will use two Peerless 850490 and a tweeter (Vifa D27TG-45-06)
Please someone, if the above xo-filter is incorrect, will someone be kind to draw me a correct xo for 2½-way system, 2nd Linkwitz-Riley.
Peerless 850490 = 8 Ohm each
Vifa Tweeter = 6 =Ohm
/pixaren
Old 10th December 2003, 06:19 PM   #5
I'd quite happily post one if I could but I can't without
a large investment of time, effort and investigation.
Its much more complicated than you seem to think.
If you haven't bought the drivers, build a published design.
Old 10th December 2003, 07:30 PM   #6
Vigier is offline Vigier  Netherlands
Hi sreten,
you can NOT use this schematic if you want a good sound, because of the induction of the HDS205 units (that's the "name" of the 850490 units).
You'll have to correct this with a filter with a R and a C.
I'll calculate it for you, just a few minutes...
Grtz, Joris
Old 10th December 2003, 07:43 PM   #7
Hi joris,
you seem to be confused, but if you can help pixaren great !
Old 10th December 2003, 07:53 PM   #8
What do you think of this?
Grzt, Joris
Old 10th December 2003, 07:57 PM   #9
By the way, I already rounded the values of the components to match the E12-series, so these are not the EXACT calculates values, but with the difference in T/S parameters (between datasheet and measurements), it doesn't matter that much.
Grtz, Joris
Old 10th December 2003, 09:34 PM   #10
hi Vigier,
looks lot better but the low bass should be rolled off according
to the baffle width by a first order inductor, -3db ~ 400Hz,
not a second-order filter.
The relative sensitivity of the the tweeter and mid bass unit
is not accounted for.
Fix the above and it will work, but there is no account taken of
the frequency and phase response of the drivers, and the
compensations possible via manipulation of the crossover.
sreten.
Can this crossover work in my speakers ? kyu Multi-Way 5 5th September 2008 10:28 AM
matching speakers with an active crossover newbie06 Digital Source 9 7th October 2006 11:03 AM
crossover help for Hales speakers Evan Shultz Multi-Way 8 24th October 2004 03:55 PM
speakers or crossover first. kvos Multi-Way 7 30th August 2003 12:15 AM
Page generated in 0.11215 seconds (79.74% PHP - 20.26% MySQL) with 11 queries
