Waveguide adapters bad idea? - Page 3 - diyAudio
Old 12th July 2013, 06:47 PM   #21
gedlee is offline gedlee  United States
gedlee's Avatar
In my experience, once a compression driver on a horn or waveguide has been properly EQ'd, they are all basically the same if they have the same size diaphragm and voice coil. I know that this is blasphemy around here, but it is my experience and I have seen nothing that indicates that this is not correct, only subjective claims to the contrary. Those, of course, being less than ideal evidence of anything.
Old 12th July 2013, 07:01 PM   #22
IG81 is offline IG81  Canada
IG81's Avatar
Is it also your experience that different diaphragm materials will not matter once all EQ'ed the same? I have yet to try such close enough comparisons, though it should be easy with the miniDSP.
IG
Old 12th July 2013, 08:54 PM   #23
gedlee's Avatar
Not a lot of experience with different materials, but suffice it to say the differences are going to be mostly above 10 kHz where I cannot see it making much audible difference on music.
Old 13th July 2013, 02:45 AM   #24
AllenB is offline AllenB  Australia
I take this to suggest they'll be free of excess phase once fixed. Suppose one wanted to locate internal reflections, the potential for IMD, breakup vs VC distortion, for finer adjustments etc., can this be done simply but reliably?
Old 13th July 2013, 02:34 PM   #25
gedlee's Avatar
Alan
The real question is are these things audibly important?
Excess phase? Do you mean group delay? I would not expect much differences here from the drivers.
Internal reflections? These get EQ'd out so they aren't a factor.
IMD? I don't believe that nonlinear distortion is a factor.
breakup vs VC distortion? I am not sure what that is so I cannot comment.
In my studies of compression drivers with B&C we found that the only significant audible differences between drivers was in frequency response, which could be corrected with EQ.
Old 13th July 2013, 08:06 PM   #26
gtb is offline gtb  Europe
I tried the DE250 on 4 waveguides :
- RCF H100
- QSC 152i
- Pyle PH612 (econowave)
- SEOS-12
Each time, I got hash sounding on a lot of material, especialy female voices. In fact, it's not a matter of taste but a matter of pain : it hurts my ears. So I tried to lower the response above 10kHz (was flat before). It seems to resolve my problem : less pain.
So I guess the problem comes from the DE250 that is harsh sounding somewhere above 10kHz. I don't know about the BMS compressions. Perhaps I will give them a try.
Old 13th July 2013, 08:31 PM   #27
Face is offline Face  United States
Face's Avatar
If the DE250 on a SEOS-12 is harsh, something is definitely amiss.
"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Old 13th July 2013, 09:12 PM   #28
I'll know soon enough.
Old 14th July 2013, 12:31 AM   #29
macsaif is offline macsaif  Slovakia
Gtb
which waveguide you prefer from the 4 mentiomed?
Old 14th July 2013, 02:33 AM   #30
Default Hip Shot
So much for the O.S.W.G. arguments in your papers, you just equalized them “all” away.
Of course this philosophy works well in a setting where it is claimed that the distortion produced cannot be heard even though it most certainly exists and is measurable.
If Be is used to make the diaphragm of a given size it will be acoustically smaller than its plastic, aluminum or titanium counterparts; and because of this, it will certainly perform differently as the onset of breakup modes and mass roll-off will occur at higher frequencies whether we choose to hear them or not.
WHG
Is this a bad idea? bart_dood Power Supplies 2 11th January 2013 09:50 PM
An inexpensive Gedlee/Bouska waveguide/tweeter midbass idea. makingmoney Multi-Way 45 17th May 2011 01:59 PM
Painting Heatsinks..I Know..Bad Idea valveitude Parts 30 9th March 2007 02:38 AM
Is this a bad idea? Jimmy154 Multi-Way 3 24th November 2002 12:18 AM
is this a bad idea? ChesterFuzzin' Multi-Way 2 28th June 2002 05:15 PM
Copyright 1999-2017 diyAudio
