Old 8th December 2003, 05:34 PM   #1
K-amps is offline K-amps  United States
K-amps's Avatar
Default How to shield and unshielded driver?
If one has unshielded drivers, whats an easy way to shield them?
I have some 1 inch wide copper tape, (The kinds used to shield the winding sides of E+I transformers.) So can I wrap the magnets with that?
Any ideas?
Old 8th December 2003, 05:47 PM   #2
MarkMcK is offline MarkMcK  United States
Here is one thread that might provide suggestions.
will this simple shield work..?
Cup shields or bucking magnets are the typical way to go. If you have access to a blacksmith, they should be able to fabricate a custom metal cup type shield inexpensively.
Good luck,
Mark
Just a ps type edit to my reply about your tag. I do not mean this as a criticism, I am just interested in it. Sand is mostly silica, silicon dioxide (SiO2). Silicon (Si) is never found in a pure state in nature. What a boon it would be to microchip manufacturers if pure Si did occur naturally and we could just pick it up off the beach. If I could pick up pure Si from sand I would be making my own power transistors.
Old 8th December 2003, 05:50 PM   #3
I'm sure that won't work.
If they are simple cabinets glueing tin or zinc plated steel to
the side walls of the cabinet will work. Just glueing a plate
to the wall nearest the TV would probably work well.
/sreten
Old 8th December 2003, 06:33 PM   #4
BobEllis's Avatar
Zalytron used to sell "silent shields" or something like that - iron cups that fit over Focal magnets. They may still have them, although I didn't see anything on the website.
Shielding affects the T-S characteristics somewhat, so be sure to measure after installing whatever form of shielding you end up with.
Old 8th December 2003, 06:38 PM   #5
This is a job for scotty.
Toroid transformer, shield or not to shield? bays_9a5tt Digital Line Level 10 21st December 2008 02:10 PM
active cable shield driver in a phono amp -- does it make sense (noise- or sonicswise Onvinyl Solid State 0 1st June 2008 09:53 AM
unshielded speakers and computers Dan2 Everything Else 3 15th November 2007 07:03 PM
using unshielded drivers near tweeters.. ractis Multi-Way 3 31st May 2007 04:01 PM
How to shield cabinet using unshielded drivers? feke67 Multi-Way 17 7th November 2002 10:09 AM
Page generated in 0.07863 seconds (71.28% PHP - 28.72% MySQL) with 10 queries
