Enclosure for EL166 - diyAudio
Old 1st July 2013, 10:40 PM   #1
KyleinCowichan's Avatar
Default Enclosure for EL166
Hello,
I was lucky enough to win a set of white EL166's at last year's Vancouver Island DIYFEST and it's time to put them to use. Dave from Planet 10 eNabled the drivers and did a full set of T/S measurements:
Re: 7.09
FS: 39.67
Qes: 0.55
Qms: 3.35
Qts: 0.47
Vas: 26.65
dB/2.83v: 87.11
Sd: 13498 (I am assuming that's square MM?)
BL: 7.11
Mms: 15.64
Cms: 1029.42
I have plugged those settings into WinISD and it's come back with a 25L box tuned to 36hz with a 2"x7.8" vent. I should note that this is the first time I've tried to design a box from measurements and I don't really know if WinISD is suggesting anything useful.
I have a few tweeters to try with it as well as some full-range drivers to try pairing up. Ideally the top end is going to be modular and sitting in it's own enclosure.
Anywho, if anyone has any other thoughts on bass-reflex or other style of enclosure for this driver I'd love to get some input!
Kyle
Old 1st July 2013, 11:10 PM   #2
vinylkid58's Avatar
I get a slightly flatter curve with a bit more extension, but I'm using the factory TS numbers and a newer version of WinISD (0.50a7). That's quite an old version you have there.
Either way, the EL166 has stupid good bass extension in a 25L box.
jeff
Old 1st July 2013, 11:53 PM   #3
Hi Jeff,
I think you're running the Pro version, I'll check it out!
At least that's something to start with. Hopefully I can spare a few mins to look at some box designs in Sketch Up and see what they'd look like. The vent configuration can be tweaked as time goes on.
Kyle
Old 2nd July 2013, 12:08 AM   #4
vinylkid58's Avatar
I really like the look of Colin's (Toppsy?) stand mount BR, with the EL166 & ERT26 tweeter. I started a 28L Onken style box, but really didn't finish it. Along came a pair of A12p Super Pencils.
jeff
Old 2nd July 2013, 12:41 AM   #5
frugal-phile(tm)
planet10's Avatar
Use the factory data. My numbers are useful formatching.
You have heard Scott's tall ML-TLs, footprint will be similar to a stand mount.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 2nd July 2013, 12:54 AM   #6
Hi Dave,
Understood RE measurements.
I like the MLTL but to facilitate swapping the top end I wanted the driver near the top of the enclosure and the woofer height relative to the total length is critical in the MLTL if I recall.
Do you think that Scott's MLTL is just about ideal for EL?
Kyle
Old 2nd July 2013, 12:56 AM   #7
jeff
That looks like it'd be a bruiser! I can understand why you were distracted.
KM
Old 3rd August 2013, 05:41 AM   #8
A brief update. Vancouver Island DIYFEST is looming and I have made some quick progress in two nights. I decided to build a totally boring 25L bookshelf format box. I wanted something fairly generic that I could use for future projects. The baffle will be removable. I am going to brace the sides and tops with some scrap 5/8 BB on edge.
Kyle
PS: reached my clamp limit tonight. I must look out for the next Canadian Tire sale!
Old 6th August 2013, 09:46 PM   #9
One more quick update: I am nearly ready to make a little sound. I should be able to fire them up tonight if I can get an hour or so in the garage. I will be using my miniDSP for the crossover.
Kyle
Old 12th August 2013, 04:34 AM   #10
I finally have something listenable. Just doing some basic tuning. I don that've any measurement gear so it's just by ear at the moment. Perhaps some golden eared folks at VI DIYFEST can offer some opinions!
Kyle
EL166 MTM ML-TL planet10 CSS 123 5th July 2013 10:34 PM
EL166 "built in baffle step compensation" sreten Multi-Way 3 23rd April 2012 12:45 AM
Building MA Woofer #6 (AKA EL166) ML-TL FAST zman01 Markaudio 0 27th November 2011 05:43 PM
Differences in T/S parameters between CSS EL166 and Woofer No6 Rullknufs Markaudio 2 26th August 2011 06:40 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
