Wiring on a crossover?
Old 1st July 2013, 09:30 AM   #1
oszkar is offline oszkar  Romania
Default Wiring on a crossover?
I am going to go plain on this one? How to? I have them all in front of me and in these speakers for them to be complete, 2 fullranges will go in as midranges! Thank you!
Old 2nd July 2013, 07:29 PM   #2
Generic George is offline Generic George  United States
Originally Posted by oszkar View Post
I am going to go plane on this one? How to?
It's not clear what you are asking for help with.
Do you want to know something about those crossovers, presumably for that speaker?
Do you want to know how make a crossover like that?
It is clear that english is not your first language, but please try to be more specific about what it is you want to know and what it is you are trying to do.
You might want to run what we say and what you are trying to say through Google translate. It may help.
Old 2nd July 2013, 07:38 PM   #3
Oh I see where I mistaken here ok! Check the other answers that I got on a similar thread about this and btw it was that I wrote this after 16hrs of work or something like that before I got to bed! What I want to say is I made a replica recalculated of PIONEER CS-V50F, the crossovers I did get them in an auction and they are HECO ASCADA 770 crossovers! I will put into these 2 full range drivers in each speaker as midranges with separate built-in cabinets! How to wire all of them speakers, they are 8 ohms each!
Old 2nd July 2013, 07:39 PM   #4
http://www.diyaudio.com/forums/multi...770-3-way.html
Here is the link to the other post!
Old 2nd July 2013, 07:50 PM   #5
And check this out by language and psychological talk: A electronic specialist if asked, will know how to make the work, but will not know how to explain what he has made in the end... Can't remember quite the paragraph but it makes an idea... The forum said help by audio fanatics for audio fanatics... I came here for help... If I am asking for some, can I get some? Something else, that is not in any kind something else thathelps me?
Old 2nd July 2013, 10:22 PM   #6
Crossovers are not interchangeable between speakers.
You would be better off starting from nothing, than trying to use the crossovers from a completely different speaker.
You are essentially trying to take the motor from a boat and use it in a motorcycle. Yes they are both motors, but they do completely different things and work in different ways, even though they function on the same principles.
It is a BAD idea to use two tweeters. You only want one.
Multiple full range speaker drivers are not a good idea either. Nor do you want to combine them with a tweeter either.
This whole project is a bad idea basically and you don't know enough to create the kind of speaker you want to.
Pick a design that already works. There are many out there. Build that.
Buy at least 1 book on speaker design.
THEN if you want to learn more, you can experiment on it. Since at the very least you will have a point of reference.
Invest in tools to measure how well the speaker works. Without them you are essentially blind. The human ear is not an accurate measuring tool.
You are not supposed to end every sentence in english with a "!". It doesn't help you make sense.
Old 3rd July 2013, 12:04 AM   #7
Dissi is offline Dissi  Switzerland
Hi Oszkar,
The first crossover consists of two coils and a black capacitor. This is the low-pass filter for the woofer.
The other crossover is for midrange and tweeter. The filter for the midrange is on the right side and has two blue capacitors (120 uF and 15 uF). The filter for the tweeter is on the left side and has a yellow and a silver capacitor (6.8 uF and 4.7 uF).
I hope this is correct. Pictures of the soldering side of the crossover boards would help to verify!
Old 3rd July 2013, 05:51 AM   #8
Ok! To fill you guys up upon this story: Now 14yrs ago I have heard the original speakers from PIONEER! Now two years ago i have seen how they are built! First I have got the drivers and tweeters I do not know ever for sure if tweeters and midranges or fullranges are drivers but if put into this phrase it will do the necesary understanding readout proposition! I bought all the drivers BASS 4.pcs., Mid.4. pcs., Tweeters 4.pcs. The man I bought them from was to have the crossovers built for me with all parameters for bass t/s i mean as parameters, electrical resistance for tweeters and the t-s parameters for the midrsnges as they will get each pair own cabinets! In the end the person that I working with left me asside with the project in course, so I was looking for crossovers with specs so that I might hit something but near results each time so I tripped into these HECO ASCADA Crossovers and said 2nd order for the tweeters is alright and their cutting frequency at 3500hz won't burn them, bass 150 hz I would of needed 250hz cutfrequency but already built and no more stress with missunderstanding waiting for days an shipment I can live with it quite good, midrange was just a question of getting the riht driver for the start/cut frequency as I remember from a specsheet that I don't have anymore is 150 - 3500hz! So I said ok! Ordered the boards to make the speakers! to weeks later I got them! In four days I built the boxes and fitted in the drivers, in another 1 week got the dampening material! Filled them up, painted them by hand in black and it is that they will get a sheet of black fabric that resembles rubber at the surface that will make them look even better and will keep everything in a better manner into place! Now what I do not know is how to wire all of them up! What I have done until now is I have mounted into place the crossover boards into the speakers and wired to them as folowing: Bass +/+ to + of the outgoing to the amplifier speaker wire and -/- to - and the same with tweets, on tweeters + with another + and - with - that went to the crossover + and respectively - afterwards the crossover wire on the speakers outgoing wire to the amplifier, the same wire that holds the bass wire also. I listened to them for a while but now they are disconnected for 3 weeks until I get the cabinets for the midranges in and the midranges also in! The tweeters are not so high as I would have expected them to be in a matter of sound reproduction in the high frequency reproduction section! Thank you!
Old 3rd July 2013, 09:47 AM   #9
Here are some more picutures for real to see how thay look, the black fabric is what will be glued with some sticky on their front
Old 3rd July 2013, 09:53 AM   #10
I can not post only 4 pictures at a time, this is all that I can brig up as data to you guys, I listen more to electronica, chillstep, dubstep and trance Deepdish style, these speakers are perfect for me, if I can squeeze a little more highs from the tweeters than is more than good for me! and watch movies
Wiring on a crossover?Hide this!Advertise here!
Inductor wiring for crossover KickMeElmo Analog Line Level 3 15th September 2011 11:47 PM
help wiring crossover eastonc Multi-Way 4 25th February 2011 09:46 AM
Help w/crossover wiring babgrip Multi-Way 7 13th December 2008 07:00 AM
Crossover wiring, common - ? squidbait Multi-Way 4 26th March 2004 06:22 AM
I need help wiring a simple crossover shadiedog87 Pass Labs 6 6th December 2003 03:03 PM
