LoudSnail - Page 2 - diyAudio
Old 7th July 2013, 03:24 PM   #11
6.283 is offline 6.283  Germany
The BF32 is not very loud but there are several alternatives from Visaton. Also the Aurasound NSW2 and Peerless P830970.
2Pi-online.de
Old 7th July 2013, 09:03 PM   #12
usul27 is offline usul27  Switzerland
usul27's Avatar
The Peerless is already a bit too large, the Aurosound might fit. The efficiency of the BF32 would not be a problem, because I want to do a active setup.
Old 8th July 2013, 08:01 AM   #13
The efficiency becomes a problem once the driver goes intro compression or later hits mechanical limits.
I would not expect too much from two watts But for the price give it a try.
2Pi-online.de
Old 8th July 2013, 08:32 PM   #14
usul27's Avatar
I will test the BF32 and see how it performs. But there is still lots of work to do until I can really test drivers. The tweeter housing is not even designed yet...
Old 8th July 2013, 08:55 PM   #15
usul27's Avatar
What about the Vifa OX20SC00-04 tweeter? With a 24db crossover it should be possible to use it down to 1.5kHz. What do you think?
Old 9th July 2013, 07:02 PM   #16
The problem is the high Fs. The response rolls off at 1100Hz. That roll-off and the filter slope combined will give you phase issues in the cross-over. Also, I would assume that distortion goes up.
Imo, this tweeter should only be used 2Khz and up.
2Pi-online.de
Old 10th July 2013, 08:36 PM   #17
usul27's Avatar
I think I'm gonna do some tests with some small fullrange drivers to see how they perform. Still haven't finished the design of the tweeter housing :-(
Old 13th July 2013, 08:56 PM   #18
usul27's Avatar
I think I'm gonna do some tests with a fullrange driver (Jordan) first. More coming soon...
Old 14th July 2013, 06:42 PM   #19
usul27's Avatar
The setup with the Jordan:
Unfortunately the thread is now in the wrong forum ;-)
Old 15th July 2013, 04:16 PM   #20
Greebster's Avatar
but not once you add the tweeter
Copyright 1999-2017 diyAudio
