Hello all. How do I put 700gm weight on Adire Audio pasive radiator. peterpan
#2 | |
diyAudio Moderator Emeritus
This is from the Adire web site for the PR 15. "Attached to the center of the MDF diaphragm is a 2.5" OD cardboard tube. This tube is used to connect the diaphragm to the full spider. And it also makes a VERY convenient place to add additional mass to the PR, is needed. Fill the tube with the desired amount of silicone, epoxy, or other material (fender washers and modeling clay work great), and you're guaranteed to have the mass centered and supported between the surround and the spider. No cantilevering of the PR at all!"
Rodd Yamashita |
| Biamp with high-mid pasive filter. | ubaid88 | Chip Amps | 1 | 19th April 2009 05:31 PM |
| pasive crossover help | lolojr1 | Parts | 5 | 17th January 2005 09:38 AM |
| A weight vs. linear weight | gary f | Multi-Way | 1 | 2nd April 2004 02:23 PM |
| mdf weight | jeffm | Multi-Way | 6 | 21st November 2002 11:18 PM |
| Page generated in 0.06598 seconds (67.51% PHP - 32.49% MySQL) with 10 queries |
