This is my first time putting together my very own speaker system, so I'd like to hear some thoughts on what I've come up with so far. The point of this project is to replace my crappy old pc multimedia speakers with an inexpensive two way system in a small sealed enclosure. Here is what I've got so far:
Woofer: Dayton 6 1/2 inch shielded tweeter: TANG BAND 28-847SA SHIELDED NEODYMIUM DOME TWEETER Placed in a sealed enclosure 0.167 ft^3 (4.7 L). The box has a Qtc of 0.76. All of these calculations were made using WinISD. The crossover I was planning on constructing was a fourth-order Linkwitz-Riley with the crossover point at 2500 Hz, and a zobel network on the woofer. I decided to go with a fourth order crossover to avoid pushing the tweeter too hard in the lower frequencies, even though the crossover will be bulky and somewhat expensive to make($20 for each channel). My questions are: 1. Does anyone have any experience with these two drivers? 2. Am I going overkill with the crossover? Would a second or third order crossover be more appropriate? 3. Are metallized polypropylene crossover caps worth the extra cost over electrolytic capacitors? Do they sound significantly better or show better performance? (I suppose this is more of an opinion question) 4. Will the inductors cause problems with my monitor? The speakers will be right up against it, hence the shielded speakers. Thanks for all the input. ChemMan |
#2 |
So no one sees any problems worth commenting about? Great.
#3 |
just another
Hi ChemMan,
I looked at the freq response curves of the drivers you are talking about last night and almost posted but figured I'm not that experienced with things like this and someone else would probably say something more meaningful...... I wasn't that wrapped with the response curves, but since this is a cheap project to as you say "replace your crappy computer speakers", I guess that they won't be too bad. I haven't yet ventured into crossover design, but looking at the repsonse curves of the two speakers my gut feel would be that maybe you should consider a xover at 1.5Khz rather than 2.5Khz (I think with a 600Hz resonant freq the tweeter should handle that), I'm assuming that these speakers won't be being thrashed with high wattage Jump in and say this is a really bad idea everyone out there with more experience than me if I'm giving a bum steer here!!!!!! The reason I'm suggesting the above is that the mid/bass dips pretty badly just after about 1.5K but has a peak at about 2.8K whereas the tweeter has a dip at about 2K. I'm guessing that the peaks at the end of the mid/bass' response may actually flatten out the dips in the tweeters response if you move the crossover point down. All wild speculation, but maybe has some merit I think the only other thing I can give input on is that I believe there have been studies done that show that electrolitics do actually introduce distortion, I believe this is quite measurable, but I could be wrong, this is of course heresay on my part Regards, Tony. |
#4 |
Do not use electrolitics in your crossover. Get the better caps. I would also recomend going with a 2nd order crossover if you choose 2500Hz. This should save you some $$$ on the crossover. The 28-847 should be fine. I crossed mine with a 1st order @6500Hz.
#5 |
Great, thanks for the comments.
| Input on 5.1 diy setup, budget friendly *n00b* | Blazin_Jason | Multi-Way | 18 | 20th January 2009 09:32 PM |
| Input transformer: floating input = distortion | ErikdeBest | Tubes / Valves | 13 | 20th January 2009 09:36 AM |
| HELP: BJT input op-amp's input bias current compensation | frickecello | Solid State | 6 | 19th June 2007 12:00 AM |
| Adding a third input to a differential input stage? | maudio | Solid State | 15 | 11th October 2006 02:16 AM |
| current bias j-fet input 2sk170 ,2sj74 at input stage | YUTK | Solid State | 11 | 2nd June 2005 03:34 AM |
| Page generated in 0.09857 seconds (76.89% PHP - 23.11% MySQL) with 10 queries |
