Parallel Baffle step filter? - diyAudio
Old 22nd June 2013, 10:37 PM   #1
Ronion is offline Ronion  United States
Default Parallel Baffle step filter?
Is it possible to build a parallel baffle step filter using a capacitor?
I have a ton of caps and a need to build a light weight baffle step--well actually a shelving filter.
It seems to me this should be a simple thing, but Google turns up nothing.
Thoughts?
Old 23rd June 2013, 12:25 AM   #2
Default Linkwitz to the rescue
Active Filters
Equalizer (passive).
Now if someone could help me make sense of them... I'm a bit thick when it comes to circuits. The drivers I'm using are 40Ohm. I can't really get the exact reactance, but even a generic filter should be simple enough to experiment with and get right. I need a 5dB cut centered around 1500Hz.
Thanks for any reply! I'm a bit anxious about trying it.
Old 23rd June 2013, 04:43 AM   #3
sregor is offline sregor  United States
These filters are designed to go between the preamp and the power amp, or in a tape deck loop. A little easier to digest is ESP description at Baffle Step Compensation.
It also can be done at the speaker level - i.e. 2.5 or 3.5 way designs. It also can be done with passive components, but loose efficiency (I believe a parallel RL circuit of the right values in series with the speaker can do this).
Parallel capacitor works only with an in line resistance, and still need a resistance in series with the capacitor. - you loose a lot of efficiency, and load down amplifier. In your case, with a 4 ohm speaker, need a 2 ohm resistor in series with your speaker, then a cap and a 4 ohm resistor in parallel with your speaker. If they are 40 ohm ?? then would be 20 ohm in series with the speaker , and a 40 ohm in series with the capacitor in parallel to to speaker. These are for 6 db drops - would require some calculation (or trial and error to figure out 5 db drops - slightly higher value resistor in series with the cap, and should be lower value on the series resistor.with the speaker. My 2 cents.
Steve
Old 24th June 2013, 11:56 PM   #4
It would have the same circuit topology as a Zobel, a resistor & cap in series,
you'd need to ensure that the R wasn't so low as to cause problems with the amp...
Impedance varies with frequency, use impedance plots of your drivers and make crossover calculations using the actual impedance of the driver at the crossover frequency
Old 25th June 2013, 01:15 AM   #5
A zobel topology doesn't change response - the circuit just draws more current. You'd have to add series resistance first, like sgregor said.
Old 25th June 2013, 03:45 AM   #6
re:"A zobel topology doesn't change response " - I can't agree with that...
Old 25th June 2013, 04:31 AM   #7
Well it's not a subjective issue. counterexample?
Old 25th June 2013, 05:41 AM   #8
think about how a simple treble cut tone control (e.g. as used in gutars) works - same topology
Old 25th June 2013, 04:05 PM   #9
Well sure, with 1MΩ impedance it works, but we're talking about changing the response of a speaker/driver.
Old 25th June 2013, 07:28 PM   #10
Paul W is offline Paul W  United States
Paul W's Avatar
Are you working external to an existing speaker? Your first post asks about BS compensation with a shelving filter while your second post mentions a cut "centered about 1500" which sounds like a notch filter. Assuming you are working externally, the hi-cut shelving filter (BS comp) would be a parallel RL in series with the speaker, a notch filter would be a parallel RLC in series with the speaker.
Paul
Audiostatic baffle step filter AAaF Planars & Exotics 56 27th February 2015 09:24 PM
baffle step compensation, zobel, notch filter dondiba Full Range 13 4th June 2012 01:10 AM
serial filter baffle step compensation Marcelinho Multi-Way 2 17th May 2011 01:42 PM
Baffle size and shape -> baffle step saschagabor Multi-Way 1 14th December 2010 11:45 AM
baffle step in serial filter Marcelinho Multi-Way 0 30th June 2006 11:56 PM
Copyright 1999-2017 diyAudio
