Sealed enclosure experiment - Page 6 - diyAudio
Old 19th July 2013, 03:42 AM   #51
Greebster's Avatar
From what I remember modeling this type of enclosure once you raise the range you'll see another peak up high.
Simmed with TL software sometime back showed that it was best used with a high Qts, limited excursion type driver that yielded a hump in the midbass caused by the upper enclosure and then extending down through the low Q tuned resistive port into the lower enclosure where the whole is tuned deep.
The driver I used was a peerless 6.5" with a healthy Xmax and a QTS of around 0.5. It was handy because optimum acoustic suspension was ~0.5' and optimum BR was ~1.5'
There was one ratio divided enclosure that must have been a fluke because there was a massive resonance around 300Hz that yielded a broad peak of at least 10dB more than what the driver is capable of, ending with a reduced/shelved low end response. Thought of Danley at that moment, standing there laughing, shaking his finger at me saying that's not it!
Old 14th August 2013, 09:14 PM   #52
4Torr is offline 4Torr  United States
Default Found it - The Dynaudio Sirius Enclosure
Double chamber aperiodic enclosure.
http://www.gattiweb.com/images/dynaudio/sirius2.pdf
http://www.gattiweb.com/dynaudio.html
Old 14th August 2013, 10:03 PM   #53
Greebster's Avatar
two variovents
Old 15th August 2013, 12:05 AM   #54
Originally Posted by Greebster View Post
two variovents
Sirius-ly damped !
Help best sub for sealed enclosure harmonizer Subwoofers 7 5th August 2011 08:55 AM
Experiment on acoustic enclosure T101 Full Range 2 28th May 2010 02:24 PM
Sealed enclosure questions.. Defo Multi-Way 6 21st February 2009 02:54 AM
Jordans in sealed enclosure? billnchristy Full Range 3 19th November 2006 04:23 PM
Small sealed enclosure Ddeele Subwoofers 15 20th January 2005 08:50 AM
Copyright 1999-2017 diyAudio
