Sealed enclosure experiment - Page 3 - diyAudio
Old 12th July 2013, 06:48 PM   #21
This is basically the Dynaco A35 enclosure.
Old 13th July 2013, 11:22 AM   #22
Yes, it seems to be a slightly similar design, except that in the A35 the chambers are separated by a kind of cloth-damped slot.
http://p10hifi.net/TLS/classics/imag...-A35-plans.gif
Maybe this damped tube approach might be more useful for those mid-woofers with higher Qts value to reduce the pronounced mid-bass response. This Peerless woofer has Qts value of 0,44. It seems like there might not be much advantage in using this kind of double-chamber enclosure with this particular Peerless unit.
Old 13th July 2013, 03:01 PM   #23
Greebster's Avatar
yup a simple resistive port
Old 13th July 2013, 03:04 PM   #24
Greebster's Avatar
what's that... a 35-38 year ago design?
Old 13th July 2013, 05:40 PM   #25
It's not slightly similar - it's the same. Aside from the specific volumes and tunings, etc., the resistive slot is equivalent to your "20x4 cm cardboard tube stuffed lightly with poly wadding from both ends". A port with some stuff in it is a port with some stuff in it . As for when this type of cabinet would be best, I don't know. I suppose you could look for measurements of impedance, bass response, and driver parameters from an A35 and see what it looks like the benefit was there.
Old 13th July 2013, 11:36 PM   #26
dumptruck,
Thanks for your clarification.
Old 14th July 2013, 01:44 AM   #27
Wouldn't you say that a resistive slot is a type of controlling device very different from the damped resonance of a vented system? Of course what the OP is working with is a different type of vented system as the exit of the port is to a second chamber. I don't understand the meaning of "A port with some stuff in it is a port with some stuff in it".
Old 14th July 2013, 02:30 PM   #28
4Torr is offline 4Torr  United States
Thanks for your advice. This time I placed the microphone exactly 3 mm away from the dust cup and set the sine wave volume in such a way that the dB meter reading was exactly 100 dB at 200 Hz frequency.
The first chart shows the frequency response in a cabinet with a 40x4 cm cardboard tube that was lightly stuffed from one end.
The second chart shows the frequency response in a 34L sealed cabinet.
The data shows decreased sound pressure level around 44-88 Hz area in the "vented" cabinet, while there seems to be a very slight level increase in the 14-34 Hz area. 100-120 Hz output is also higher in the vented cabinet.
Dynaco, shmynaco, back to the experiment...
Which impedance curve corresponds to which response curve?
Old 14th July 2013, 04:02 PM   #29
Here is a composite chart with measurements from 34-litre sealed cabinet (blue, red) and a cabinet vented with 4x40 tube (yellow, green).
Old 14th July 2013, 05:43 PM   #30
Wow - the green line looks like a classic bass reflex Z curve and the yellow line spl dip corresponds with the maximum driver damping from the tuned box. If the port were vented to the outside air, the dip would be a gain in overall spl. Instead the energy is dissipated inside the cabinet.
Nice experiment !
Help best sub for sealed enclosure harmonizer Subwoofers 7 5th August 2011 08:55 AM
Experiment on acoustic enclosure T101 Full Range 2 28th May 2010 02:24 PM
Sealed enclosure questions.. Defo Multi-Way 6 21st February 2009 02:54 AM
Jordans in sealed enclosure? billnchristy Full Range 3 19th November 2006 04:23 PM
Small sealed enclosure Ddeele Subwoofers 15 20th January 2005 08:50 AM
Copyright 1999-2017 diyAudio
