Starting an Active Open Baffle design.
Old 7th July 2013, 04:53 PM   #121
Rudolf is offline Rudolf  Germany
Rudolf's Avatar
Originally Posted by DrDyna View Post
I drug one of them outside this morning so I could get the MiniDSP set properly and the xml file saved so I could load it into the second one when it gets here.
Here's the result and what I did to get it. .... What do you guys think?
If this http://www.diyaudio.com/forums/attachments/multi-way/358275d1373039991-starting-active-open-baffle-design-minidsp-screen1.jpg
are your electrical correction filters, you basically got it wrong IMHO.
DrDyna, you just have become the victim of my sadistic urge to make things perfect. It’s not your fault – you just stood in the way.
Please let me explain why your approach is basically wrong. I will start with an EDGE sim of a 100x60 cm OB and a 15” driver centered at 27 cm from the bottom:
You can easily see how all dipole baffles start with a 6 dB acoustic high pass at low frequencies. Our example keeps this high pass to its dipole peak at 500 Hz (which is recognizable because the dipole dip at 1 kHz is clearly visible). It is very clear that the acoustic high pass will influence everything below 500 Hz.
Next simulation is for a real world Visaton BG 40 in this baffle:
It shows the 0, 30 and 60° response. You will notice how the real driver changes the response to a degree, but basically the baffle response rules. Note how the proportions of both diagrams are kept equal.
Next I have stretched the 0° response a bit along the x-axis to give room for the next filter variations:
I now consecutively applied a 6 dB electrical low pass at 50 Hz (black line) and an additional 12 dB electrical low pass at 100 Hz (red line). The non-EQ response is dashed:
Note how the acoustic high pass below 50 Hz is almost unchanged – it is almost 12 dB!
Note how the 6 dB electrical low pass not only straightens out the response (you can easily imagine to equalize it with some parametric EQs into the green range). It applies a falling acoustic response curve at the upper end of the woofer range too. Same for the 12 dB electrical low pass. Its influence at the lower end is small, but it works full tilt as a response leveler around 100 Hz and a cut-off above 100 Hz. Effectively nobody applied a real electrical low pass at 200 Hz, but we have got a working acoustical 20 dB low pass above 200 Hz.
Things get even worse when you install a passive EQ:
You remember the black dashed line? The continuous black line is the passive response with the 12 dB electrical low pass shown in the picture. You achieve an amazing 24 dB acoustic high pass below 50 Hz and a comparatively decent acoustic 12 dB low pass above 300 Hz.
What do I want you to understand in all this mess? It is the wildly different approach to filter design you have to take with dipoles. Symmetrical electrical crossovers are wrong in almost every case. You need to shape the acoustical response for every driver range to the intended form before you should even think about the application of over-all filters.
In my own case I have implied parametric EQs for the individual drivers only – there is not a single EQ for the summed response!
Rudolf
www.dipolplus.de
Old 7th July 2013, 05:48 PM   #122
DrDyna is offline DrDyna  United States
DrDyna's Avatar
Originally Posted by Rudolf View Post
If this diyAudioare your electrical correction filters, you basically got it wrong IMHO.
Attachment 358637
Attachment 358638
Attachment 358639
Attachment 358640
Attachment 358641
Rudolf
I'm really making an honest attempt to read and digest all of this, but it's probably going to take me some time to figure out what I should change.
What I did when I measured was to measure each driver (with the others turned off) with the crossover engaged, and EQ a flat response within each band that I was trying to get each driver to cover.
Right now, if I play only one driver (the woofers together, or the midrage or the tweeter) they play relatively flat in the range that I've chosen.
Is the idea that the ranges I've picked for each driver should be different so that they are more "symbiotic" with naturally occurring dipole peaks and dips, or is the idea that what I've done is completely incorrect?
I really want to get this right, it's a learning experience for me, and I appreciate the time you spend talking about this with me
Edit: attaching measurements of the individual drivers. (not level matched)
Old 7th July 2013, 07:10 PM   #123
Rudolf's Avatar
the individual curves of your drivers look decent enough - except a detail in the Neo response, which I will approach later. And the regions for each driver(s) are well choosen. I have no argument with them at all.
My curiosity is about the crossover regions, filter orders and phase relations mainly. Did you measure every two neighbouring regions together - in phase and one out of phase? It seems you are going with LR filters. Did you get the LR-typical 6 dB difference at the Xover frequency between single driver curves and summing curves? Deep notches for the inverted case?
Have you done off-axis measurements which you would show? What happened to the high-pass of the midrange driver? It doesn't work lower than -20 dB?
For the Neo3 I don't see any significant response dip at 7 kHz. This would be indicative for too much baffle area seen by the Neo3. Or did you apply some EQ there already? Which should not be done without parallel off-axis response control.
I hope that I don't come across too demanding or smart-alecky. Hopefully I'm only squeezing the best out of you.
Rudolf
www.dipolplus.de
Old 7th July 2013, 07:52 PM   #124
DrDyna's Avatar
I'm not sure about the high pass on the mid, really I just picked where I wanted it to work and went with it. As far as summing, I didn't have to do too much, except for the midrange, which I applied a small amount of delay (0.15ms) and watched the dip in the response rise until it was where it looked good, then I stopped adding delay.
I do probably need to do more work, and that's what I'm looking for. I'm at a spot right now where it seems to be "ok", but I'm really looking for hints and tweaks to make it better.
The responses in the screenshots I posted are after EQ. They represent the chosen XO frequencies, (48db/oct, although I've been trying some 24). Some of it was quite peaky before EQ. I really try to do most of my EQ through subtraction, what I did was input the range of interest for each driver into REW and let it generate an EQ curve that gave me a reasonable response, then I added a little "flavor" or my own to the final EQ, such as a little dip around 6-7k to get rid of some sibilance. (that's not in the screenshots)
Rudolf
Oh, no no no, please...I can handle criticism, that's how these things get better! I will honestly try to absorb any information you give, and I will try as best I can to make a good attempt to make any corrections or implement any advice.
You won't hurt my feelings at all. <3 In fact, if I make major changes to anything, I keep all the xml files for the MiniDSP so that I can inspect them and try to learn through listening what each change means. I'm totally fine with having a minidsp-rudolf.xml So far, any changes that I've made that were a result of feedback have been mostly positive, so, by all means...
Give me sh*t!
Old 7th July 2013, 09:14 PM   #125
DrDyna's Avatar
Also, after reading over this a little more, I guess what I need to do is do some off-axis measurements. I'll try to do some tomorrow.
Old 7th July 2013, 10:29 PM   #126
Rudolf's Avatar
Give me sh*t!
Some observations of my Neo3. First a comparison of my equalized system (free hanging Neo3 on top from 2.5 kHz upward). On-axis measurement on tweeter height from 40 cm distance (top) and from listening position (bottom):
You see how the 7 kHz dip gets more shallow with distance/reflections and off-axis. At 30° the response is quite smooth without any EQ:
Measurements are 0-90° at 10° intervals. 30° is pink.
If REW is trying to equalize that 6-8 kHz hole - don't allow it. This EQ will be a severe source of sibilance.
Listen to the response hole without thinking about the curve.
www.dipolplus.de
Old 8th July 2013, 06:50 AM   #127
gainphile is offline gainphile  Australia
gainphile's Avatar
I had thought about raising it up high, I remember seeing the photo of when you measured yours and it was up on an ironing board
So, I guess it should be up for only the mid measurement? I remember Rudolf saying that the woofers should be near the ground, a concept I'm familiar with, which is why I left it where it was.
Out of curiosity, what sort of effect will measuring it like I did have on the mid?
Yes, the ironing board
Correct, only for midrange. Especially to find that pesky frequency, depth, and Q of that midrange dipole peak!
For tweeter, indoor with gating of 4-6ms is good enough.
For woofer, at under 100hz I don't think you can get any farfield useful, even raised 2m. I just do a nearfield (1-2cm at mouth), indoor.
http://gainphile.blogspot.com
Old 8th July 2013, 11:31 AM   #128
DrDyna's Avatar
Attachment 358684
Attachment 358685
Yeah, at first I allowed it to EQ the tweeter flat, but the sibilance drove me crazy..they were hissing at me! So I went into the DSP and started bypassing filters until the dip came back, and I even added a little more dip by creating a 1db drop from 6k to 7.5k. Now they just sparkle, and Eva Cassidy doesn't make me want to jump from the window
It would seem from your measurements though, I could actually just adjust the listening axis a few degrees and get the same effect. That is on the list of stuff to try today
I have a lazy susan downstairs, I'm going to try and do some off-axis measurements once the sun is fully up today.
Awesome, thanks. I'll see what types of measurements I can get today, and I also plan to try some other measuring software (tolvan) to see if it can tell me anything additional.
Edit: Rudolf, one other thing, do you have a version of your page that's in english? Google translate fails to translate it
Old 8th July 2013, 11:54 AM   #129
Juhazi is offline Juhazi  Finland
Juhazi's Avatar
Drdyna, based on my experience, you should use milder (12/24dB/oct) xo slopes. They come sort of naturally with dipoles and they help to mix drivers' polar responses more evenly.
When measuring outdoors - set the speaker on a stand and on grass to minimize "floor" reflection! 3-5' is good distance, IRgate 3ms for tweeter -9ms for mid-20ms for the low end of the mid or woofer section. Tell us what IRgate you used in the measuremnts that you show us. Generally for measuring the speaker alone - use short IR (3-12ms) and when checking/ eqing room response - use long gate (60-200ms)
Otherwise - keep going! About the tweeter - it's dispersion is important about how it sounds. I like mine when direct is flat and 15¤ response rolls off a little. But the amount/degree of this depens on your tweeter's type/characteristics (and your ears and room reflections).
AINOgradient speaker project
Old 8th July 2013, 11:59 AM   #130
DrDyna's Avatar
I actually changed the slopes to 24db/oct yesterday, but I haven't measured it yet today. We shall see!
Otherwise - keep going! About the tweeter - it's dispersion is important about how it sounds. I like mine when direct is flat and 15¤ response rolls off a little. But the amount/degree of this depens on your tweeter's type/characteristics.
I'm hoping to be able to use Tolvan's Sirp today to do some gated measurements, I'm looking forward to what I can learn from it.
Starting an Active Open Baffle design.Hide this!Advertise here!
Single Ended Active Crossovers for Open Baffle Speakers ljfont Solid State 10 21st October 2015 05:09 AM
Active Crossover for Open Baffle 2-way mortron Analog Line Level 17 9th December 2012 08:40 PM
Open Baffle active Xo/EQ/Amp design Zicdave Multi-Way 0 15th May 2012 09:55 AM
Please recommend a 4 or 5" FR for Open baffle w/ active bass augmentaion JandG Full Range 19 9th July 2010 05:54 AM
Open baffle design help fin1bxn Full Range 4 5th February 2007 03:07 AM
Copyright ©1999-2017 diyAudio
