Modify position of woofer in cab w/ new baffle? - diyAudio
Old 20th June 2013, 03:27 PM   #1
rongon is offline rongon  United States
rongon's Avatar
Default Modify position of woofer in cab w/ new baffle?
First off, this question is the result of my being a completely incompetent woodworker. My friends tease me about this. Oh well. I have learned to live within my limitations.
I have a pair of Klipsch KG4.5 "monkey coffins." I got them cheap, to try out, but I'm tired of them. I figure they'd make decent woofer boxes, though. These cabs are about 2.4 cubic feet/68 liters. Here is a picture of the ugly beasts:
I would cut away the original baffle, leaving a border that would allow me to to glue a new baffle onto the front of the cab. This would allow me to cut a new hole for mounting the woofer in a different place. I'd like to move the woofer closer to the top of the cab, as close to the top as possible. Sort of like this, but bigger and wider:
That way I'd be able to sit a horn tweeter right on top of it, minimizing the distance between the acoustic centers of the woofer and tweeter. That would make it easy to experiment with different horns, etc. by simply perching the new horn on top of the cab.
So, is there a problem with locating the woofer close to the top of the speaker baffle? I figure that would be a good thing as regards diffraction, no?
Adding a tall thin woofer cab to bookshelf speaker? ChuckT Multi-Way 1 9th March 2011 09:06 AM
Woofer choice for small cab PeteMcK Multi-Way 8 12th June 2009 05:48 AM
Best woofer for 6 litre cab? jaste Multi-Way 1 15th September 2008 12:41 PM
Woofer and port position DragonMaster Multi-Way 2 13th September 2008 11:18 PM
Port position on Bass cab Gubbe Instruments and Amps 1 17th February 2006 04:40 PM
Copyright ©1999-2017 diyAudio
