Crossover explanation - Page 2 - diyAudio
Old 21st June 2013, 12:01 AM   #11
Mrhjelm is offline Mrhjelm  Sweden
Thank you all for your contributions! I've now got a better idea of what is going on.
Can resistors affect the phase? I thought only caps and coils where involved here? Something you can clarify?
Old 21st June 2013, 01:17 AM   #12
Resistors are phase neutral. The current neither leads or lags the voltage.
The builder is making very fine adjustments to the crossovers. Again, we have to trust that he knew what he was doing. I also suspect this is not the crossover he started out with. I suspect he started with the basic, tested, redesign, refined, and tested again, the redesigned and refined until he got the result he was looking for.
Steve
Old 21st June 2013, 03:38 AM   #13
wintermute's Avatar
The resistor will subtly change the transfer function of the filter and this will also affect the phase. The effect on the actual spl curve may not look that great but it's what happens with the phase that is interesting. I've found that a resistor inserted into a shunt leg like this (and tuned appropriately) can make the difference between poor and good phase matching at the crossover frequency.
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
I need an explanation. Alexrmc92 Instruments and Amps 25 12th October 2011 08:51 PM
Explanation wanted Hojvaelde Tubes / Valves 8 28th May 2011 03:37 PM
ignorant crossover questions: looking for explanation Bob Simons Multi-Way 5 25th October 2010 12:16 PM
Schematic explanation johnnystulic2004 Solid State 1 20th October 2010 05:11 PM
Explanation for this problem? Rob11966 Tubes / Valves 4 22nd September 2007 05:39 AM
Copyright 1999-2017 diyAudio
