Old 6th December 2003, 07:28 PM   #1
BAM is offline BAM
Send a message via AIM to BAM
Default Dipole Woofer Page
This is a web page chronicling a guy's Linkwitz PHOENIX-style dipole subwoofer design. It looks extremely slick and if I weren't a dipole skeptic this is the sort of thing I would aspire to with my own design. It even integrates a plate amplifier!
http://sho.mystarband.net/BBContent/BBBass.html
Old 6th December 2003, 08:33 PM   #2
navin is offline navin  India
navin's Avatar
Send a message via MSN to navin Send a message via Yahoo to navin
why dipole skeptic?
...still looking for the holy grail.
Old 7th December 2003, 04:40 AM   #3
BAM is offline BAM
Default Why I am a Dipole Skeptic
It seems to me like an extremely inefficient way to produce bass. Everything I have been taught tells me that a dipole radiator will not be able to produce the same amount of bass as easily and cheaply as a sealed box, reflex box, bandpass box, transmission line, aperiodic box, MAPD box, infinite baffle, basshorn, Acoustic Wane Cannon, or other types of Assisted Resonance box that isolates the back wave from the driver. Now, I have never actually heard a dipole bass system but I believe an assisted resonance subwoofer can outperform it in quantity while matching it blow for blow in quality.
Old 7th December 2003, 08:14 AM   #4
AndersZ is offline AndersZ  Sweden
A dipole sub is not about quantity, it's about quality. The point is to skip any kind of resonance and stored energy while at the same time utilise the dipole radiation to minimize standing waves.
Try it and see for yourself
Anders
visit The ZedEn projects
http://www.t.kth.se/andzak54/
Old 7th December 2003, 09:02 AM   #5
Dommi is offline Dommi  Germany
Hy Bam,
I also use Di Pole bass with my Prometheus system, because the bass is better. First i used a sealed Box with one aktive and one passive speaker. The problem was that the bass seems to be deeper in Frequency, but it wasen't. It was only that he had less precision and so the bass semms to muble. Now with dipole the frequency is about 25 Hz and is verry verry precise.
On my Homepage you can see the Dipole integrated to my Prometheus system ( by the way a verry verry cheap loudspeaker system, but sounds better than the most of this expensive High End-LS !! )
Dommi
Old 7th December 2003, 03:40 PM   #6
Raka is offline Raka  Europe
Raka's Avatar
There are times like this, when I'd love to speak german...
What is beyond the speaker?
Old 7th December 2003, 06:50 PM   #7
Previously: Kuei Yang Wang
ThorstenL's Avatar
Default Re: Why I am a Dipole Skeptic
Konnichiwa,
You are absolutely right. But getting a certain amount of output at a given frequency tells very little of the actual story.
Funny thing you know. I once designed a Dipole Sub for a friend where it was considered essential due to dipole nature of mid & Treble. Using quite inexpensive 18" Pro-Audio drivers and inexpenbsive 500VA PA Amplifier Modules these 22" Cubes produce a quantity AND quality of bass I have yet to hear from conventional subwoofers in a similar size.
Admittedly, using dual 18" Woofers with > 100db TS derived sensitivity for the pair and and +27dbW power applied to the pair of drivers with a Qt over 0.5 and a sub 30Hz resonance helps tremendously in minimising the applied EQ and thus maximising SPL Capacity.
In short, these are some MEAN mother subs and they sound a lot cleaner and offer much faster in room LF decay (making individual notes much more distinct) than ANY monopole sub.
MAYBE some really big, bricked in Horns will outperform them, but at a tremendous amount of work....
Sayonara
Old 8th December 2003, 05:56 AM   #8
@ Raka
Hy, it's not neccssery to speak german.
I can give you a small summary about my Page. I'll try to give tips about buying and using Hifi and High End. Most of the persons don't know about some manufacturer which produce verry good High End for a verry fair price. They can mail me what they will spend for Hifi, and i try to find a good manufacturer. I also try to give some tips using Hifi accessories like Spikes or power distribution ecc. ecc.
If you want further informations don't hesitate to mail me
regards
Dommi
Old 8th December 2003, 10:49 AM   #9
Raka's Avatar
Originally posted by Dommi
@ Raka
regards
Dommi
Thank you very much
Dipole Ribbon tweeter isolation from dipole mid-woofer array Bent Planars & Exotics 5 21st May 2009 12:10 PM
Dipole woofer how high johnb Subwoofers 3 5th November 2005 10:11 AM
Newbie Dipole woofer help please... santiu Subwoofers 5 30th October 2005 07:20 PM
W shaped dipole woofer - some help needed. Mattias S Multi-Way 17 17th December 2003 09:40 AM
Page generated in 0.10851 seconds (79.97% PHP - 20.03% MySQL) with 10 queries
