I am considering building speakers using these woofers. I have been looking back and forth at various designs and done some modelling but have zero practical experience in the speaker section of DIY. I will be using a digital crossover (Behringer) with home-made amps. I am aiming for great performance in a small package and transient response, preferably with deep extension. I am willing to EQ the bottom to achieve that. Here are the datasheets: Focal 11WX http://www.focal.tm.fr/gb/compo/woofer/a_11wx.htm Focal 13WX http://www.focal.tm.fr/gb/compo/woofer/a_13wx.htm What worries me a bit for the smaller unit is the Xmax of only 3.5mm. What worries me quite a bit for both units is that an expert I had a chat with suggested these drivers were highly optimized for vented designs. I don't know the reasoning behind that. What also worries me is the very small enclosure sizes recommended. I see Focal is using similar 13" driver (possibly different) in the Nova Be http://www.focal.tm.fr/gb/home/utopiabe/novabe.htm and the volume of the box is VERY LARGE at about 125 litres. I am gunning for something significantly smaller - probably 80 litres or less for the bass box. Your comments would be greatly appreciated. Petter |
#2 |
usually focal woofers are built for bass reflex or TLs but i guess a program like bass box or box plot will help you detmine what teh woofer will do in a sealed box.
as far as transiest response goes extensive EQ will also affect transient response of the system. Q: why are you considering only these 2 woofers?
...still looking for the holy grail. |
#3 |
Because I can get them at a discount, and because I was initially planning to replicate the commercial models offered by the same manufacturer. I have pretty much decided to use Focal tweeter and midrange because I like it's sweetness.
I must also confess that the speakers sure look sexy ... (I also have a Scanspeak speaker under development, but that is a far less costly effort Petter |
#4 |
love to know your SS plan too. do they include the XT tweeter, sliced cone mids and new 10" woofer?
#5 |
ScanSpeak project:
My other project is basically a modification of attached image - concrete loudspeakers that used to be quarter wave resonators, now reflex. I purchased the elements too early, so I did not get into the slitted bass elements. I worked quite a bit to get them to fit ... it is rather tight - had to use a milling machine on the tweeter "reflector" and cut away some of the 18cm bass elements edges The tweeter is a 2905/990000, the bass elements are from memory 18W8546 as they fitted the volume at hand better. Petter |
#6 |
On cursory inspection the 13 is the better bass unit
and the recommended volume is 80L to 100L. I'm sure the recommended volumes are near industry standard - max this and that for volume - but of course less volume efficient alignments are available to to the amateur and exotic manafacturers. |
| FS: Tannoy M1, Focal 11WX | igor0203 | Swap Meet | 0 | 20th July 2009 06:17 PM |
| Focal Audiom 13WX For Sale $700 obo | Quantum Waves | Swap Meet | 1 | 17th March 2009 08:35 PM |
| how to make a sealed box for some focal utopias 5ws | BILLYZ | Car Audio | 11 | 14th April 2005 06:31 AM |
| MTM design FOCAL 6W4311 AND FOCAL Focal TC120 Tdx2 | Bas Horneman | Multi-Way | 1 | 5th February 2003 04:21 PM |
| Page generated in 0.08540 seconds (76.52% PHP - 23.48% MySQL) with 11 queries |
