There is a fair amount of useful discussion in the archives about appropriate T/S parameters for dipole woofers, but I couldn't find so much about mids or mid woofers. Does it not matter so much, because you simply cross the woofer higher with a higher Qt mid woofer?
Related question: it doesn't seem from first glance the most of the available speaker modeling software addresses dipole response. Any recommendations? Sheldon |
#2 |
It does matter but not a great deal.
A second order high pass can be easily used to compensate for the frequency response due to to the units Q. At frenquencies above the baffle width wavelength the mids response on the forward axis is independant of loading, i.e. its the same in a box and on a baffle. At lower frequencies response is heavily influenced by the room and the position of the dipole in the room. Anechoic response is modeled by a 6dB/octave rolloff. |
#3 |
Thanks,
It would be interesting to have a program to play with response, depending on baffle dimensions and speaker placement on the baffle. I would think that it would not be that hard to model. Or is it easy enough to experiment, so not worth the effort to develop the model? That seems one nice thing about using conventional drivers on an open baffle. Real easy to make a small baffle, then just extend it in various dimensions to evaluate response. Sheldon |
#4 | |
The truth need not be veiled, for it veils itself from the eyes of the ignorant. |
#5 | |||
Previously: Kuei Yang Wang
Konnichiwa,
If you are using (for arguments sake) a 5.25" Driver with a Qt of 0.3 and an Fs of 50Hz with a 500Hz X-Over on an open baffle the result will be fine, as by the time you reach 500Hz the drivers efficiency has reached the maximum. If for arguments sake you where to use the same driver with a 100Hz X-Over you would have to equalise the driver heavily as there would be a substantial loss even at the X-Over frequency. Quote:
http://www.exdreamnet.de/download/Xlbaffle.xls It is an Excel Spreadsheet that runs under Microsoft Excel 2000 (probably also 97/XP but not tested) but NOT under any other Office Software like Star Office. The baffle assumes ideal assymetric placement of the driver on the baffle (meaning making the distance to each and every edge non-divisible by any other) and takes account of room re-inforcement (inaccurate but close enough until I have time for a re-write) but not of room modes. Sayonara |
#6 |
Thanks, makes sense. Goes with the impression one gets from looking at the freq response curves drivers that differ in Qt (that is, if such things are measured under similar conditions, which they don't often seem to be).
I did try to download the spread sheet yesterday, but the link on the thunderstone site didn't work. This one does, Thanks. Sheldon |
#7 |
http://cargocollective.com/stevedodd...ge-of-the-Nerd |
#8 | |
Banned
Working on changing that feature. Jocko |
#9 | |
Thanks, let me take the opportunity to ask a related question: On the dipole woofer side, some installations use a w type frame with the woofers facing and the box openings facing the listener. This obviously shouldn't affect Lf sound, but what is the upper cuttoff where internal reflections begin to become audible? Sheldon |
#10 | |
Konnichiwa,
Just being pragmatic, no axe to grind.... Sayonara |
| hey guys QUICK question | Shpoop | Multi-Way | 3 | 23rd July 2009 05:27 PM |
| mids and highs question | mike49504 | Car Audio | 1 | 3rd March 2009 09:33 PM |
| Mids question | Dan2 | Car Audio | 31 | 12th March 2008 03:45 PM |
| Seas Excel mids vs. dayton rs mids in dipole | sqlkev | Multi-Way | 2 | 10th July 2006 06:28 PM |
| Tubes driving dipole mids | rick57 | Tubes / Valves | 20 | 26th August 2005 10:55 PM |
| Page generated in 0.14346 seconds (82.19% PHP - 17.81% MySQL) with 11 queries |
