FRD and other Jeff Bagby spreadsheets - Page 2 - diyAudio
Old 17th June 2013, 11:53 PM   #11
LibreOffice has limited support for VBA. It won't run the macros in PCD, WBCD, Baffle Diffraction or the Frequency Response Modeler.
The Woofer Box and Circuit Designer (WBCD) was "converted" to .NET several years ago. The .NET version has evolved separately, but it still uses the same Benson model that Jeff Bagby implemented in his original Excel version. Converting the Excel equations proved to be a laborious task, so I wrote completely new versions of PCD, Baffle Diffraction and Frequency Response Modeler. They are implemented differently but should provide the same results. Part of the new design approach was to integrate these tools into a single program, where calculation results from one module are passed along to the Crossover Module. This results in an easy-to-use integrated tool that does measurement file processing, Box modeling, Baffle modeling, Amp/EQ modeling and Crossover Design.
This integrated program is PSD-Lite. It is still a Beta release but it is fully functional and reasonably mature. The final version is getting a Thiele-Small database--it will be available soon.
PSD-Lite can be downloaded here: http://www.audiodevelopers.com/Softw...Lite/setup.exe
This version of the program is free, and it will remain so. There is a "Pro" version with more features and an "Active" version that can directly control DSP chips.
Old 17th June 2013, 11:57 PM   #12
Face is offline Face  United States
Face's Avatar
I've used PCD and PSD-Lite, PSD-Lite is just as easy to use, if not easier.
"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Old 18th June 2013, 10:10 AM   #13
jamikl is offline jamikl  Australia
Neil Davis are you saying that PCD lite will run with Libre Office. I have tried the others with Open Office, Gnumeric and the spreadsheet in the Ashampoo office set =- all to no avail. I lost the copy of MS Office I had when the hard drive failed and didn"t have a copy of it - must have lost it in a house shift about 18 months ago. As I am on a basic Australian pension some of the programs which may be cheap to others are quite expensive to!. I thank you all for your help.
jamikl
Old 18th June 2013, 12:32 PM   #14
PSD-Lite is a .NET click-once application. No Excel or Office of any sort required. All you need is .NET 4.0, and the installer will take care of that for you.
Old 18th June 2013, 03:52 PM   #15
Boxsim (free stand-alone program) can do the same things as PCD. It is a bit more confusing, maybe, on account of incorporating more features/variables. I use both pretty regularly.
Old 19th June 2013, 10:41 AM   #16
Thanks Neil Davis and dumptruck. I now have PSD lite and have had boxsim for awhile so I guess I don't need much else. ABC dipole works OK with libre Office too so that's a big help.
jamikl
Modelling the Pensil CHR70 with the Martin King Spreadsheets Malco Planet 10 hifi 6 7th February 2013 01:19 AM
"The CSS 'Next Generation' High Resolution 'Triton' Kit" designed by Jeff Bagby woodsart Multi-Way 88 29th December 2012 12:44 PM
Hello from Jeff Jeffs Introductions 5 19th October 2011 07:12 PM
Tapered TL satellite prototype questions for MJK spreadsheets skov Full Range 3 1st March 2006 02:54 PM
Jeff Rowland ben goh Analogue Source 0 14th May 2005 06:04 AM
Copyright 1999-2017 diyAudio
